A pendulum with viscous friction
18 replies · 3K views · last reply
Insights Author
TL;DR
Not a challenge merely unexpectedly solvable by hands problem
Consider the standard pendulum with a weightless rod of length b and a mass point m and mg is applied. In the hinge there is a torque of viscous friction which is proportional ##\omega^2##.
Now release the pendulum from the horizontal position. What biggest height does the point m attain after its first passing through the vertical position?
Let me know whether I got you. Is the equation of motion
[tex]L=ml^2\dot{\theta}[/tex]
[tex]\dot{L}=ml^2\ddot{\theta}=-mgl\sin\theta-k\dot{\theta}^2 sgn\ \dot{\theta}[/tex]?
I get the following eq of motion:
$$ mb^2 \ddot \theta + \beta \dot \theta^2 - mg b \cos \theta = 0 $$
You are saying this is analytically solvable?
Note the important additional factor ##\text{sign} \dot{\theta}## written in #2. That's also what I'm puzzled about. I don't see, how to solve the question posed in #1, because I don't see how to calculate the energy loss due to friction without solving for the equation of motion first, and that's for sure not easily done in analytic form. Even the frictionless case leads to elliptic functions! Maybe @wrobel gives the solution, he has in mind soon?
Let me see, how far a I get. Using the EoM given in #2, with ##\theta## being the angle wrt. the direction of ##\vec{g}## as usual. Then the energy of the pendulum is
$$E=\frac{m b^2}{2} \dot{\theta}^2 - m g b \cos \theta,$$
and
$$\mathrm{d}_t E=\dot{\theta} (m \ddot{\theta} + m g b \sin \theta)=-k |\dot{\theta}|^3.$$
From this I don't see, how to calculate the energy loss without knowing the solution of the EoM :-(.
Would we have to have the sign factor if we are just trying to get to the first turning point?
Yes,
$$\dot \theta=\omega(\theta),\quad mb^2\omega'\omega+\beta\omega^2-mgb\cos\theta=0$$
and $$\omega'\omega=\frac{1}{2}\frac{d}{d\theta}\omega^2$$
a linear equation with respect to ##\omega^2(\theta)##
wrobel said:
Yes,
If that term that has ##\cos \theta ## was a constant ##k## its solvable with the substitution ##u = \beta \omega^2 + k ## , but it's not constant?
wrobel said:
Yes,
How do you get to this equation? I still don't see, how to answer your problem, about the height after "one swing" analytically.
I rewrote the equation from post 3. The standard trick:$$\dot\theta=\omega(\theta)\Longrightarrow \ddot\theta=\omega'\dot\theta=\omega'\omega$$
gives a first order linear ODE with respect to ##\omega^2(\theta)##
$$ mb^2 \frac{d \omega}{dt} + \beta \omega^2 - mgb \cos \theta = 0 $$
$$ mb^2 \frac{d \omega}{d \theta} \frac{d \theta}{ dt} + \beta \omega^2 - mgb \cos \theta = 0$$
$$ mb^2 \frac{d \omega}{d \theta} \omega + \beta \omega^2 - mgb \cos \theta = 0 $$
While it is true that
$$ u = \omega^2 $$
$$ \implies \frac{du}{d \theta} = 2 \omega \frac{d \omega}{d \theta} $$
would convert that to a linear equation, it is not true that ##u =\omega^2## is a viable substitution given the non-constant term ## mgb \cos \theta## that remains in the equation.
Great, but shouldn't it be the EoM in #2?
Even in no friction case elliptic integral is tough for me. I am afraid there is no analytical solution to find at least for the beginners like me.
It would be nice to see what level of a “hands” solution this is. I suspect it will be entirely lost on me, but I’m always curious about stuff I can’t comprehend.
wrobel said:
I do not know what EoM is and I do not understand what is written in 2.
Introduce a notation ##y(\theta)=\omega^2(\theta)## then the equation from 3
takes the form $$mb^2y'/2+\beta y=mgb\cos\theta.$$
To solve it use the method of variation of a constant
https://personal.math.vt.edu/renardym/class_home/firstorder/node1.html
EoM=equation of motion, and I think the correct equation of motion, with ##\theta## counted relative to the direction of ##\vec{g}## is
$$mb^2 \ddot{\theta} + k \dot{\theta}^2 \text{sign} \dot{\theta} + \frac{m g b} \sin \theta.$$
I do not have any other words to explain this standard technique. But I think if you ask it in the topic "Differential Equations" then maybe there is more gifted and more patient educator than me.
@wrobel I am curious to know how you treat ##cos\theta## term as g(t) in the variation constants method and the final result of maximum angle to reach.
