A. Physics Frictional force
In summary: You need to resolve the weight of the block into components along and perpendicular to the incline. You will see that the force of static friction acts up the incline with a magnitude of 349.06 N.In summary, the block at rest on the incline has a force of static friction of 349.06 N acting up the incline. The largest angle the incline can have for the block to not slide down is 33.82 degrees. The acceleration of the block down the incline with an angle of 37 degrees is 5.586 m/s^2.
narcoyam
A block is at rest on the incline shown in the figure. The coefficients of static and kinetic friction are µs= 0.67 and µk = 0.57, respectively.
The acceleration of gravity is 9.8m/s^2
1. -> What is the frictional force action on the 42kg mass?
Answer in units of N.
N = mg cos x
(42) (9.8) cos (32) = 349.0565964
then 0.67 = Fs/ 349.0565964
so the answer is 233.8679196N
2. -> What is the largest angle which the incline can have so that the mass does not slide down the incline?
Answer in unit of degree.
0.67 = tan x
x= 33.82208522 degree
3. -> What is the acceleration of the block down the incline if the angle of the incline is 37 degree?
Answer in units of m/s^2
a=-ukg
so (-0.57)(9.8) = 5.586m/s^2
But this is wrong
I'm not sure if my answers are right but 3rd one is definitely wrong
can you check if this is right? Thank u
Part (1) is incorrect. You say that the force f static friction has reached its maximum value when the angle is 32 degrees. That is not correct. As you calculate in part (2), the force of static friction reaches its maximum value when the angle is 33.82 degrees.
In part (1) the force of static friction is whatever is necessary to keep the mass at rest. Draw a free body diagram to find what that is.
For the third question, the acceleration of the block down the incline can be calculated using Newton's Second Law: F=ma. In this case, the only force acting on the block is the component of its weight parallel to the incline, which is given by mg sin x, where x is the angle of the incline. So we have:
F=mg sin x = ma
Rearranging for a, we get:
a = g sin x
Substituting the given values, we get:
a = (9.8) sin (37) = 5.886 m/s^2
So the acceleration of the block down the incline with an angle of 37 degrees is 5.886 m/s^2.
1. What is frictional force in physics?
Frictional force in physics refers to the force that opposes the motion of an object when it is in contact with another object or surface. It is caused by the interaction of microscopic irregularities between the two surfaces.
2. How is frictional force measured?
Frictional force can be measured using a device called a dynamometer, which measures the force required to pull or push an object on a surface. It can also be calculated using the formula F = μN, where F is the frictional force, μ is the coefficient of friction, and N is the normal force.
3. What factors affect the amount of frictional force?
The amount of frictional force depends on several factors, including the roughness of the surfaces in contact, the force pressing the surfaces together, and the type of material the surfaces are made of.
4. How does friction affect motion?
Frictional force acts in the opposite direction of an object's motion, making it harder for the object to move. It can also cause objects to slow down or stop altogether, as it converts kinetic energy into heat.
5. How can frictional force be reduced or increased?
Frictional force can be reduced by using lubricants, such as oil or grease, between two surfaces. It can be increased by increasing the force pressing the surfaces together or by using rougher surfaces that have a higher coefficient of friction.
