How much water will freeze when a piece of ice is thrown into it?
  • Thread starter Thread starter Karol
    Ice Water
A 50-gram piece of ice at -10°C is introduced into water at 0°C, and the discussion focuses on calculating how much water will freeze around the ice. The heat absorbed by the ice as it warms to 0°C is calculated using the specific heat of ice, resulting in 275 calories available for freezing. This energy can freeze approximately 3.45 grams of water, as it takes 79.7 calories to freeze one gram of water. The calculations confirm that the specific heat of ice must be considered to arrive at the correct answer. The final conclusion is that about 3.45 grams of water will freeze around the ice.
Karol
A 50 gr piece of ice at temp' -100C is thrown in water which is at 00C.
How much water will freeze around it. no heat is lost or gained from outside.
Specific heat of ice: 0.55
Melting heat: 79.7[cal/gr/C0]
The ice comes from -10C0 to 0C0 by taking heat from the water. this amount of heat freezes the water:
##50[gr]\cdot 10[C^0]=79.7\left[\frac{cal}{gr\cdot C^0}\right]\cdot m\rightarrow m=6.3[gr]##
Is it correct?
Where did you take the specific heat of ice into account?
Also, your units do not match, but that has the same error as origin.
You have forgotten take into account the specific heat of ice: 0,55...
Solving it 'without equations', that supercooled piece of ice can absorb 50 * 10 * 0,55 = 275 cal from the outside without melting, and that 'heat debit' is used up in freezing some water that is already at 0º C, so that one gram of that water needs just 79,7 cal to freeze. You have 275 cal 'available for freezing'. Thus, you can freeze 275/79,7 = 3,45 g of water...
##0.55\left[\frac{cal}{gr\cdot C^0}\right]\cdot50[gr]\cdot 10[C^0]=79.7\left[\frac{cal}{gr}\right]\cdot m\rightarrow m=3.45[gr]##
Is it correct?
Thanks
