Deepak K Kapur said:
Two same quantities [mass and speed ( whether constant or not)] are involved in the same mathematical relation of multiplication...and... in one case the operation of multiplication says that the object moves and in the second it says it doesn't...u may feel okay with it but i can't.
You shouldn't feel OK with it. Your argument is so wrong that you cannot help but feel confused.
First, they are not they are not "two same quantities" they are "two pairs of quantities with the same units". PeterDonis has already pointed out several other examples.
Second, the operation of multiplication NEVER "says that the object moves". The operation of multiplication is simply a mathematical operation, not a physics statement. If I buy n=4 cups of coffee for p=$2/cup then the cost is k=np. That in no way means that either the cups or the price is moving.
Also, consider the fact that multiplication is commutative. So if the multiplication in ##mv^2## meant m moves with speed v then by the commutative property you would have to also say ##v^2## moves with speed ##\sqrt{m}##. Hopefully that illustrates how absurd this argument is.
In order to use a formula in physics you need to know the definition of each variable and further you need to know when it applies. You cannot randomly change the meaning of variables and expect it to still work, nor can you apply it when it doesn't apply.
In ##E=1/2\,mv^2## where m is the mass of an object, v is its speed, and KE is its kinetic energy. It only applies when the object has a uniform velocity (not rotating or deforming). The fact that the object moves at speed v is due to the definition of v and not the operation of multiplication.
In ##E=mc^2## m is the mass of the object, c is the speed of light, and E is the total energy. This equation applies only when the object has no net momentum. In other words, ##mc^2## is the energy at rest (v=0), it is not the energy of an object moving at c.
