A question about special relativity,
The discussion revolves around the derivation of the special relativity formula and its application beyond light. The original poster is confused about whether the formula, which uses the speed of light, can be applied to other objects, like a ball. Responses clarify that while the derivation is based on light's constant speed, similar principles can apply to other objects, though the specifics may differ. The analogy of a bouncing ball in a moving train is used to illustrate this concept. Overall, the conversation emphasizes the foundational role of light's behavior in special relativity while acknowledging the potential for broader applications.
hippopviolin
Hello everyone,
This is not a typical homework question. I found this confuses me when my teacher derives the special relativity formula in the class. Here is the derivation:
1. The astronaut, stationary relative to the clock incorporated in the bottom mirror, measures a time interval 2 delta t(s) for the light to make a round trip and so infers delta t(s) to be the duration of the upward journey.
2. The time interval as measured by an observer on Earth, who records it as delta t(m).
3.The path of the light forms two identical right triangles
So, the textbook and my teacher use the Pythagorean theorem to make a equation, and isolate delta t(m). Since the scenario was testing with the path of light, therefore the formula would include c square, of course.
Now, my question is: Can we use this formula for the other problems that are testing with the path of things other than light, such as a ball. If we can, should not we replace the speed of light with the speed of the ball?
I did talk to my teacher about it, but he could not find any answers yet, so I guess I may get some help here.
Sorry about my grammar. I hope I state my question clear.
Thanks to anyone who are trying to help!
Hi there,
From your explanations, you are explaining time dilation. The two right triangles that your teacher was using comes from the postulate that light always travels at the speed of light, otherwise it could be considered as a boucing ball.
Now, if I understand your question correctly, the path of a tennis ball bouncing vertically in a train passing by, would look like it's traveling in a triangle shape path for you standing still next to the train. If this is what you meant, then you can replace light photons with any object you feel like.
Cheers
Thank you fatra2 for reply my question.
looking forward to see more explanations.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
