pixel01
- 688
- 1
My question is : if two stars have the same luminosity and temperature, do they have to be at the same mass and size?
Helios said:Whoa! I think it's far too rash to make these sweeping generalizations. The previous posters #2 #3 statements "absolutely true" or "true except for metallicity" are reckless. Stars with the same luminosity could have different sizes and masses for a lot of reasons. I think the age, composition, and the radiative or convective description of the star are paramount. I don't think luminosity is any simple function of a star's mass and size. I'll await an astrophysicist's verdicit on this one.
~jet said:Apologies for the late arrival, but now I am in a position of having to ask similar questions to this; I have the task of offering up 'plausible' (if not necessary hyper-accurate) stellar statistics based on only a few initial conditions: mass (and perhaps constituency of that mass in H, He, and metallicities) versus age (how long it has been around.)
This nags me like knowing I know a word that is just beyond the tip of my tongue. I could use all these solar ratio based equations we have derived to 'guess' at a star's features, but it seems to me as though if you know initial mass you know everything. Initial gravity -> initial inward pressure -> required force to initiate fusion -> outward pressure from the energy released by said fusion -> hydrostatic equilibrium -> radius; meanwhile backtracking a bit, that released energy -> radius/surface area -> outward luminosity -> surface temperature. Oversimplistic perhaps, but is there anything missing here?
qraal said:Opacity. Heavier elements in the core means it has to be hotter to fuse and thus fusion goes quicker. That's why stars get brighter as they age on the Main Sequence. Luminosity is usually a simple function of effective temperature and stellar photospheric area - but increased opacity in very cool stars changes that simple relation.
Chronos said:The fact stars can be binned in the H-R diagram suggests common denominators - such as mass and elemental composition. Low mass, high luminosity stars and high mass, low luminoisty stars are uncommon.
Vanadium 50 said:Rishavutkarsh, I am sorry, but none of that is true. The luminosity of a star is determined by its radius and temperature.
Rishavutkarsh said:betelguese is brighter than sun ?
Vanadium 50 said:Yes. Technically, it's more luminous. The sun is brighter, but that's because it is closer.
~jet said:Sure; BG is more luminous but due to its bloated dimensions, that is spread out so much more dramatically than either the sun or proxima centauri... you average down (for lack of a better term) to a lower, redder, cooler temperature despite the greater output.
I am curious... I've ready that at outset, a star born here in this galaxy and at this time is going to have X percent hydrogen and Y percent helium and trace amounts of heavier castoffs. When all that aggregates to the point of fusion, (assuming a modest sized star) we speak of it as if it is only fusion hydrogen. Is that technically true? Is there no helium being fused at all until it reaches the end of the main sequence? My mind wants to default to believing that this is occurring in a gradient of a sort, rather than sudden flips of a switch where internal shells of alternately fusing substances materialize.
qraal said:Each "step" has radically higher temperatures and densities at which its probability of occurring rises sufficiently to actually occur, plus each successive set of reactions involves heavier elements that can sink deeper - the heavier fusion "ash" of one reaction becomes the fuel of the next layer downwards because of that.
Of course; I'm familiar with the concept of shells of fusing different elements... what I wasn't as certain about is what is there that prevents a little helium from being fused along the way prior to the formation of the first helium core? I have some difficulty perceiving the mechanisms by which, SNAP, all of a sudden a helium core spontaneously exists.
CoolYoungStar said:Hello Jet, I've been reading along and I think I have a few answers. First, helium most certainly burns in the sun; however, the core is not hot enough to support large amounts of this cycle. I believe the p-p chain is responsible for 98% of the suns energy while the CNO is second with ~1.5%. Here is my source: http://neutrino.aquaphoenix.com/un-esa/sun/sun-chapter4.html
The Sun shines because of the process of fusion...
Vanadium 50 said:If two stars have the same temperature and luminosity, they *must* have the same size. That's a consequence of stars being blackbodies, and has nothing to do with any energy generating mechanism.
turboguppy said:The sun does NOT shine because of fusion. The sun shines because it is hot. Fusion is a by-product and replenishes lost energy so that the sun may shine for a long time, but fusion doesn't cause the sun to shine.
I'm suspicious of the rest of the page as well... Most of the references are 10-20 years old.
CoolYoungStar said:First, helium most certainly burns in the sun; however, the core is not hot enough to support large amounts of this cycle. I believe the p-p chain is responsible for 98% of the suns energy while the CNO is second with ~1.5%.
~jet said:I wasn't as certain about is what is there that prevents a little helium from being fused along the way prior to the formation of the first helium core? I have some difficulty perceiving the mechanisms by which, SNAP, all of a sudden a helium core spontaneously exists.
So the heavier material sinks; that makes sense... it accumulates... does it reach, maybe, some critical mass where it begins to fuse?
It just seems to me that at the center of a star, given higher temps and pressures, some of it would be fusing prior to the formation of a shell.
We should all go dissect a star. =) I don't think the natives will mind.
