A question in different methods of a solution
  • Thread starter Thread starter transgalactic
transgalactic
i added the question and both solutions in the link
the solution that i was presented is totaly logical
but when i solved it in a standart way it gave me a different answer
http://img116.imageshack.us/my.php?image=img8272ib1.jpg
I hope it is no surprise that your book is correct. Basically the problem is this: you have a linear transformation from 2 by 2 matrices to 2 by two matrices defined by :
\left[\begin{array}{cc} a & b \\ c & d \end{array}\right] mapped to \left[\begin{array}{cc} 0 & c \\ 0 & d \end{array}\right]
Yes, since a and b "disappear" they play no part in determining the kernel. The only non-zero terms in the resultant matrix are c and d. It they are 0, then the result is the zero matrix. What that means, then, is that a and b can be anything at all as long as c= 0 and d= 0. Taking a= 1, b= 0 gives the matrix
\left[\begin{array}{cc} 1 & 0 \\ 0 & 0 \end{array}\right]
and taking a= 0, b= 1 gives the matrix
\left[\begin{array}{cc} 0 & 1 \\ 0 & 0 \end{array}\right]
Those two matrices form a basis for the kernel.
I don't think it really makes sense to talk about "a and b don't matter in determining the Image". a and b are only in the matrix the transformation is applied to- not in the resultant matrix. Obviously, every matrix in the image have first column 0. The second column can be anything. A basis for the image is
\left[\begin{array}{cc} 0 & 1 \\ 0 & 1 \end{array}\right]
and
\left[\begin{array}{cc} 0 & 0 \\ 0 & 1 \end{array}\right]
In your "totally logical" solution, you are applying a matrix to the 0 vector. The "kernel" of a transformation is the set of vectors that are mapped to the 0 vector, not that the 0 vector is mapped to. You are going the wrong way.
(Any linear transformation maps the 0 vector to the 0 vector.)
i can't understand
"not that the 0 vector is mapped to"
can you describe it a different words my mistake??
If Ax= y, then "A maps x to y".
x is in the kernel of A if and only if Ax= 0. That is, if "A maps x to 0".
For any linear transformation, A, A0= 0. That is "A always maps 0 to 0".
In your attempted solution you construct an 8 by 8 matrix and apply it to the 0 vector. Of course, you get the 0 vector. That has nothing to do with a "kernel" because that will always be true. It going the wrong way: you are seeing what 0 is changed into (mapped to) rather that seeing what gets changed to 0.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
