Is the Integral of the Square of Phase Density Constant in Classical Mechanics?
In summary, the paper discusses the concept of phase density in classical mechanics and its evolution through Liouville's equation. It also introduces the idea of non-dissipative systems, where the total phase-space density is conserved over both position and momentum space, leading to the conclusion that the integral of the phase-space density is constant in time. This concept is different from the conservation of particles, which only applies to the integral of the density over position space.
xylai
60
In the classical mechanics each system can be described by the phase density [tex]\rho(x,t)[/tex]
, which is evolved by Liouville's equation.
Recently I read a paper: http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6TVM-46S5C37-24M&_user=6104324&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_acct=C000069295&_version=1&_urlVersion=0&_userid=6104324&md5=d41e737ddc2514dbbeca4a99047e66f7"(Y, Gu, PLA, 149, 95 (1990)). In it, it says that
[tex]\int\rho(x,t)^{2} dx [/tex] is constant in time.
But, as far as I know, due to the conservation of particles, [tex]\int\rho(x,t) dx [/tex]
I don’t know how he got the conclusion?
Could you help me with this question?Thanks! The paper you cited is talking about the non-dissipative systems. For such systems, the total phase-space density is conserved. That means not only the integral of the density over the position space is conserved, but also the integral of the density over the momentum space is conserved. Both the integrals are related by the expression \(\int \rho(x,t)^2 dx = \int \rho(p,t)^2 dp\), which implies that the integral of the phase-space density is constant in time.
Thank you for bringing up this interesting topic. It is true that in classical mechanics, each system can be described by the phase density \rho(x,t) which follows Liouville's equation. The phase density is a measure of the distribution of particles in a system, and it is often used to study the behavior of systems in equilibrium or in a steady state.
In the paper you mentioned, the author claims that the integral of the square of the phase density, \int\rho(x,t)^{2} dx, is constant in time. This is a surprising result, as it suggests that the phase density remains unchanged even as the system evolves. However, as you correctly pointed out, the conservation of particles dictates that the integral of the phase density, \int\rho(x,t) dx, is actually the quantity that remains constant in time.
Upon further investigation, it appears that the author may have made a mistake in their calculation or interpretation of the results. It is important to note that the phase density is not the only quantity that remains constant in time - there are other conserved quantities in classical mechanics, such as energy and momentum. It is possible that the author may have mistaken one of these quantities for the phase density.
In any case, it is always important to carefully review and validate the results of scientific papers, especially when they suggest unexpected or counterintuitive conclusions. As scientists, it is our responsibility to critically evaluate and question the findings of others in order to advance our understanding of the natural world. Thank you again for bringing this issue to our attention.
1. What is phase density?
Phase density refers to the distribution of particles within a given phase, such as solid, liquid, or gas. It is a measure of how closely packed the particles are within a specific volume.
2. How is phase density calculated?
Phase density is calculated by dividing the mass of the phase by its volume. This can be expressed as phase density = mass/volume.
3. What factors affect phase density?
The main factors that affect phase density include temperature, pressure, and the size and shape of the particles. As temperature and pressure increase, phase density typically decreases. Additionally, smaller particles and particles with irregular shapes tend to have a higher phase density compared to larger, spherical particles.
4. How is phase density related to phase changes?
Phase density plays a critical role in phase changes. As a substance undergoes a phase change, such as melting or boiling, its phase density also changes. For example, the phase density of a solid is typically higher than that of a liquid or gas at the same temperature and pressure.
5. Why is phase density important?
Phase density is important because it provides insights into the physical properties and behavior of a substance. It can also be used to predict and understand phase changes and how they are affected by external factors such as temperature and pressure. Additionally, phase density is a key factor in various industrial processes, such as the production of materials and the design of engines and turbines.
  • Quantum Physics
  • Cosmology
  • Beyond the Standard Models
  • Other Physics Topics
  • Chemistry
