A question on The Nature of Gravity in relation to close proximity to earth
In summary: The accuracy of that equation actually increases as you move away from the Earth because, as the Earth's mass increases, the force of gravity on the object also increases.
Time Machine
54
Newton's law of universal gravitation states that every mass in the universe attracts every other mass with a force proportional to the product of their masses.
See website for diagrams: http://hyperphysics.phy-astr.gsu.edu/hbase/forces/isq.html
Inverse Square Law, Gravity
As one of the fields which obey the general inverse square law, the gravity field can be put in the form shown below, showing that the acceleration of gravity, g, is an expression of the intensity of the gravity field.
Other applications of the inverse square law Electric field Light Sound Radiation
Index
Gravity concepts
HyperPhysics***** Mechanics R Nave
Go Back
Unquote:
Place the aircraft above the surface of the Earth to the elavation of 10000ft. The distance from the Earth will calculate how much of the Earth's sphere it is exposed to and therefore the measure of gravitational pull it is feeling from the Earth. This measurement will not be inversed as the craft is now the point of focus. It will be the opposite of inversed. Now measure the aircraft's mass weight. It's weight inversed by the measurement of distance will calculate the amount of gravitational pull it is effecting on the Earth. Take the measurement of gravitational pull felt by the craft from the Earth and the measurement of gravitational pull felt by the Earth from the craft. Add these together. This is the increase in gravitational pull that an aircraft of this weight will experience at this elevation above this planet. (This obviously does not take into acount lift, induced drag, thrust, pressure, temperature or density. Only weight, elevation and gravity drag. )
If this is not the case, can anyone explain why please?
Doesn't matter how much of Earth is exposed. Gravity cannot be shielded. You are always attracted by the pull of the entire Earth's mass. It doesn't matter that most of it is not exposed to you.
Time Machine said:
...The distance from the Earth will calculate how much of the Earth's sphere it is exposed to...
This statement is nonsensical. Any object is "exposed to" the entirety of the Earth at all times. Gravity acts universally, whether there is something in the way or not.
Every single atom of the Earth - from the near side through the far side - pulls on the airplane with a force that is directly proportional to the atom's mass and inversely proportional to the square of its distance. Full stop.
Also note that that equation is for really for point masses (and, iirc, also works for uniform spherical masses). Since Earth is not a point mass and doesn't have a uniform mass distribution, the accuracy of that equation actually increases as you move away from the earth.
Thanks for your answer Dave.
The airplane's atoms also pull on the Earth with a force that is directly proportional to the atom's mass and inversely proportional to the square of it's distance.
Thinking of myself now as a "hover person" if I hover 1foot above the earth, will I be using the same force of thrust at 1foot elevation as I will at 2000ft?
Thank you for your reply Russ.
Please excuse me, I am a leyman in physics terms. Your reply interests me. Could you possibly elaborate on the differences between "point mass" and "uniform mass" and what you mean by the accuracy of that equation actually increasing as you move away from the Earth?
Cheers for your reply as well. Duly noted.
A point mass is what it says, it means you can consider the object as a point. A uniform mass distribution, would have an equal density at any point in the object, for the Earth this is not the case, for example differences in the masses of rocks and so on.
This means that as you get further away from the earth, the uneven distribution of mass becomes more negligible, as the error would get smaller as a percentage of the total mass, and hence the force would be closer to the actual force.
Time Machine said:
...if I hover 1foot above the earth, will I be using the same force of thrust at 1foot elevation as I will at 2000ft?
No. The gravitational pull of the Earth is a fraction smaller at 20,000 feet. But it s a very small fraction - about 1/10th of a percent. So, instead of (about) 9.8, it would be 9.79.
Thanks for that. Understood and duly noted.
A commercial jet plane will fly faster with increased fuel economy at optimum cruising altitude:
Despite the fact that due to lack of oxygen (low air density or high density altitude) the engine is not performing at optimum power.
Despite the fact that the minimal decrease in gravity at this level of altitude will have little effect on a plane.
Despite the fact that low air density (or high density altitude) will cause a lower rate of buoyancy.
Despite the fact that low air density (or high density altitude) will cause the wings to produce less lift.
Despite the fact that whilst thrust specific fuel comsumption is high, actual thrust out put is decreased.
Can this just be due to less drag? If so, are we talking about induced drag or gravity drag?
A jet plane in take off will, at the same level of thrust, travel more slowly at a steeper angle of ascent.
Its thrust specific fuel consumption will be far higher, at lower speeds, in higher air density (or low density altitude), during it's ascent. Although jet engines are designed to be more efficient in-taking extremely cold air found at altitude, the oxygen rich, high density air at lower altitude will afford optimum fuel combustion.
If a jet engine has high thrust specific fuel consumption at altitude due to an air to fuel mix ratio, why does a jet plane have a high thrust specific fuel consumption at lower speed during an ascent?
Can this just be attributed to increased drag due to air density?
Time Machine said:
A commercial jet plane will fly faster with increased fuel economy at optimum cruising altitude...
Yes, the biggest factor in efficiency of jet travel is drag. They go to higher altitudes because of the reduced drag from thinner air.
I do not know what you mean by 'gravity drag'.
Answered in order, yes and no. Parasitic drag, not induced drag or gravity drag, is the driving factor here. As parasitic drag is proportional to density, it is better to fly high where density is low.
It's a term used in rocketry, not avionics. The concept applies to landing on or taking off from any planetary body, including the Moon. It has nothing to do with atmosphere.
Here are a couple of ways to get a satellite from the surface of the Earth to GEO:
  1. Install the vehicle as a payload on a rocket. The rocket, usually in two stages, launches into low Earth orbit. From LEO, a third stage performs a burn to put the vehicle in an orbit whose apogee is at GEO altitude. The vehicle drifts until it comes close to apogee, at which time it performs another burn to insert the vehicle into geosynchronous orbit.
  2. Just thrust straight up from the desired subsatellite point on equator, gradually picking up horizontal speed to keep the desired subsatellite point directly below. No need for that high-G, high velocity rocketry stuff, right? The maximum speed needed with this approach is less than half that needed for a low Earth orbit.
The problem with the latter approach is that the amount of fuel required is huge. This approach has a very high gravity drag term.
DH edit. This was a mess. For one thing, looked like DaveC posted a lot of info on Cesnas; he did not. The link was completely wrong, for another. I think this is what the poster meant to say.
(A Personal Opinion)
Dr Lots-o'watts said:
The change of gravity is negligible. The actual mass of the aircraft however (and thus its weight) is considerably reduced throughout the flight as its fuel is burnt. This is much more important than any change in gravity due to altitude.
As for the relation between engine performance and altitude, here are typical numbers in the case of a propeller-driven aircraft (taken out of a 1978 Model Cessna 172 owner's handbook), running at constant 2200 RPM, 15degC - 2degC per 1000ft (in this case at least, the colder air does not compensate for the lower density):
100 knots @ 2000ft
99 knots @ 4000ft
98 knots @ 6000ft
97 knots @ 8000ft
96 knots @ 10000ft
95 knots @ 12000ft
As for the relation between climb performance (feet per minute) and altitude:
675FPM @ 2000ft
580FPM @ 4000ft
485FPM @ 6000ft
390FPM @ 8000ft
295FPM @ 10000ft
200FPM @ 12000ft
Note that the relations are typical for a specific single engine prop plane and has perhaps nothing to do with a jet engine.
Additional information Cessna 172:
Cruising Speed = 122 knots
Service Ceiling = 14200ft
Although a Cessna 172 is most certainly not a jet plane, there are similarity's in what happens for both during an ascent and again during cruising altitude. Although almost maximum power is used both at altitude cruising speed and in take off, take off is achieved at lower speeds than ascent or cruising speeds. The initial ascent happens quite fast, then ascent slows, the speed slows, and the ascent slows again as does the speed. Then the aircraft reaches cruising altitude and it all levels out. The altitude this happens at depends on how heavy the aircraft is and tweaking is possible dependent on thrust versus weight versus altitude versus engine power.
Why is the aircraft experiencing such an escalation in drag between 2000ft and 12000ft?
Gravity tails off very gradually and would have little effect on an aircraft except for the fact that the aircraft is also a mass. Newton's law of universal gravitation states that every mass in the universe attracts every other mass with a force proportional to the product of their masses.
Quote: Wikapedia
In astrodynamics and rocketry, gravity drag (or gravity losses) is a measure of the loss in the net performance of a rocket while it is thrusting in a gravitational field.
DH edit: Rest of wikipedia quote deleted.
D H said:
[*]Just thrust straight up from the desired subsatellite point on equator, gradually picking up horizontal speed to keep the desired subsatellite point directly below. No need for that high-G, high velocity rocketry stuff, right? The maximum speed needed with this approach is less than half that needed for a low Earth orbit.[/list]
Very interesting. Do you have or know where to get any data charting gravity losses in relation to velocity? I am particularly interested in the region of 0 to 35000ft.
Does anyone know where to find known density altitude parameters for temperature and air pressure charts?
I am not disputing this fact. However during my trawling around pilot forums I noticed a distinct lack of understanding as to this phenomenon due to the factors that I outlined as "despite". That a lack of air density, whilst inducing less parasitic drag also causes there to be less lift, less bouyancy, less efficient fuel consumption per thrust output, yet the craft flies faster with more fuel efficiency. Or could there be another factor behind the high fuel consumption during ascent. I suppose I'll have to get the dreaded maths involved, but in the mean time...
Apologies to Editor: Didn't know it was going to come out like that. Still learning your page parameters. Noted: Will keep quotes more to the point.
Using gravity drag here is essentially wrong in this context, Time Machine. You already are taking lift and weight into account. Adding in gravity drag is double booking lift versus weight.
The lack of understanding appears to be mostly a misunderstanding on your part.
Buoyancy is a very small fraction of weight. Try calculating the buoyancy of a fully loaded 747. You are dragging in tiny effects and are ignoring the biggest of them all, which is parasitic drag.
Lift is proportional to density and to the square of velocity. Even though density is lower at altitude, lift that counterbalances weight can be achieved at altitude thanks to the higher velocities that can be attained at altitude. There is a limit of course. Every aircraft has a ceiling above which it cannot operate; it simply runs out of wings or engines.
Well I can't argue with your reply. However gravity and gravity drag/losses are the context of my investigation. An aircraft does come under the influence of gravity and it's weight is relative to this force. Lift and thrust are essentially anti-gravity devices along with aero-dynamic design.
There is a lot of data available for how things work and at what speed for satelites and planets. Don't seem to be able to find much on 0 to 35000 ft though. Notice that aircraft use a lot of fuel and thrust between 2000ft and 15000ft to maintain speed and climb. That there is a tail off after this elevation dependent on weight and that optimum cruising altitude is achieved higher up dependent on weight and engine thrust output.
Please note that I am an enquiring mind rather than a student, however I can appreciate that as an equation, adding gravity losses to weight and lift calculations could well be a double booking. Made me think though.
What is gravity?
Gravity is a natural force that causes objects with mass to attract one another. It is responsible for keeping planets in orbit around the sun and for holding objects to the surface of the Earth.
How does gravity work?
Gravity is caused by the curvature of space-time, which is created by the presence of mass. The more mass an object has, the stronger its gravitational pull will be. This pull is what keeps objects in close proximity to the Earth.
How does gravity change with proximity to the Earth?
The force of gravity is inversely proportional to the square of the distance between two objects. This means that as an object gets closer to the Earth, the force of gravity will increase. For example, an object at the Earth's surface will experience a stronger gravitational pull than one at a higher altitude.
What factors can affect the strength of gravity?
The strength of gravity can be affected by the mass of the objects involved and the distance between them. The larger the mass and the closer the proximity, the stronger the force of gravity will be. Additionally, gravity can be affected by external forces such as the presence of other nearby objects or the rotation of the Earth.
How does gravity affect objects in close proximity to the Earth?
In close proximity to the Earth, the force of gravity can cause objects to accelerate towards the Earth's surface. This is why objects fall when dropped and why satellites orbit around the Earth. The strength of gravity also affects the weight of objects, with objects closer to the Earth's surface weighing more than those at higher altitudes.
  • Astronomy and Astrophysics
  • Mechanics
