A quick distance/time question.
  • Thread starter Thread starter skg94
To determine the vertical height of the aircraft, the round trip time of the radar pulse, 1.28*10^-4 seconds, should be halved to find the one-way travel time. The distance can then be calculated using the formula d=vt, where 'v' is the speed of the radar pulse. After finding the hypotenuse, the vertical height can be derived using the sine function with the angle of elevation of 22.0 degrees. The discussion also humorously notes a misunderstanding of the term "theta." The focus remains on applying the correct physics principles to solve the problem.
skg94
A radar pulse projected at an angle of elevation of 22.0 degrees is reflected from an aircraft and returned. If the pulse takes 1.28*10^-4s to make the round trip, then the vertical height of the aircraft is? (Height of radar transmitter/receiver can be ignored)
I know how to do it, just use d=vt to find the hyp and then use sin feta to find vertical height.
But for time do i use 1.28*10^-4s? or use half of that since that time is the round trip?
I woud do it that way, you have the right thinking... you can also use that time and get the total distance and divide that by 2...
I thought feta was a type of Greek cheese.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 19 ·
  • · Replies 19 ·
