A Rocket was launched directly upwards from rest.
  • Thread starter Thread starter heartOFphysic
    Rest Rocket
A rocket launched upwards from rest experiences a constant vertical acceleration of 6.0 m/s² for 30 seconds. The initial calculations incorrectly considered gravity's effect separately, leading to a velocity of -114 m/s. The correct approach recognizes that the motor's acceleration of 6.0 m/s² is the net acceleration after accounting for gravity. The actual acceleration provided by the motors is 15.8 m/s², resulting in a final velocity of 180 m/s. Understanding the net acceleration is crucial for accurate calculations in physics.
heartOFphysic
Hi, I have this particular question, to which i think my method is correct, though the answer from the book which this question is in gives different to mine. Please! any assistance will be very much appreciated!
Question:
A Rocket was launched directly upwards from rest. Its motors operated for 30s after it left the launch pad, providing it with a constant vertical acceleration of 6.0m/s during this time. Its motors then switched off.
Calculate its velocity.
My method:
Take upwards as + and g = 9.8
then u= 0 t= 30 a= -9.8+6 = -3.8
since V= u +at we get -3.8 X 30 = -114 = 114m/s!
BUT THE BOOK GIVES THE ANSWER AS 180m/s. (This means they've taken acceleration as 6! But surely acceleration due to gravity is acting downwards, so we need to calculate a resultant acceleration first!)
thanks
Presumably, the 6 m/s2 is the resultant acceleration, including the effect of gravity. (It wouldn't be much of a rocket if the net acceleration were downward!)
Ahhhh I get it now! so the motor is providing an acceleration of 15.8m/s^2!
hence resultant acceleration is 15.8-9.8= 6!
I wouldn't have presumed that was the case, to me 6m/s^2 was the genuine acceleration the motor provided.
Thank you for your help!
