A simple Complex Analysis Mapping
NewtonianAlch
http://img684.imageshack.us/img684/779/334sn.jpg
The first part was fairly straightforward, solve for z + 1, and then get w in terms of u + iv, rationalise the denominator, and then we get (x,y) in terms of u and v, which we substitute back into the equation of the line, and get it into the form of an equation of a circle.
The next part is not as obvious for me, I tried the same method, but I couldn't rationalise the denominator, I'm assuming the circle is shifted somehow because of the 2, but I'm not sure.
If you can't do it with complex numbers, switch to vectors.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
