A simple model of a laser ( )
In summary, the equations for the number of photons in a laser are as follows: (1) the number of photons (n'(t))'(n) = Gnp/(Gn+f) - k as n'(t) = 0 when n = 0 or n = p/k - f/g, (2) p = fk/g makes (n'(t))'(n) = 0 when n*=0, and (3) there is a saddle point between p=pc and p>pc.
Jamin2112
986
A simple model of a laser (URGENT!)
Need to turn this in 2 hrs from now. Yes, I'm a slacker.
(a) Suppose that N evolves much more quickly than n so that we can make the quasi-static approximation N ≈ 0. Given this approximation, re-write our equations as a 1-D dynamical system for n.
(b) Show that for p > pc, the "trivial" fixed point n* = 0 is unstable, and that for p < pc, n* = 0 is stable. No need to explicitly determine pc.
(c) What type of bifurcation occurs as the pump strength increases past the laser threshold pc?
(d) For what range in the parameters (G, k, f, p) do you expect the quasi-static approximation to be good?
"This will give some good intuition and background information on the physics involved. The problem we will consider is as follows. Let N be the number of excited atoms in our laser, and let n be the number of photons (particles of light) that ... [etc.] ...
n'(t) = GnN - kn
N'(t) = -GnN - fN + p,
where G is the gain coefficient ... [etc.] ...
Part (a) is easy: I have n'(t) = Gnp/(Gn+f) - k. Note that this means n'(t) = 0 if n = 0 or n = p/k - f/g.
So then (n'(t))'(n) = Gpf/(Gn+f)2 - k. Plugging in n*=0 to that gives Gp/f - k. I'm assuming that the pc in the problem means pc = kf/G ? Because then we have a situation where p > pc makes Gp/f - k > 0, and p < pc makes Gp/f - k < 0.
I've noticed also that p = fk/g makes (n'(t))'(n) = 0 when I plug in the other fixed point, n* = p/k - f/g. I'm still trying to figure out the significance of this.
Right, as this point is the border between a stable an an unstable point n*=0.
Saddle point? Could be stable.
That's why I hate these deceptive homework problems. When it says "No need to explicitly determine pb", I get the impression that pc is a value that's extremely difficult to solve for.
I think it would be considered a saddle point since there's only one fixed point when p = pc, but then another appears out of nowhere when p ≠ pc.
EDIT: It would be a "transcritical bifurcation" since the stability at n=0 changes as p is varied from p=pc to p>pc.
As for part (c), I believe this is a transcritical bifurcation. As p increases past pc, the stable fixed point at n* = 0 and the unstable fixed point at n* = p/k - f/g exchange stability.
In terms of part (d), I expect the quasi-static approximation to be good when p is large and G is small, because then the gain and loss terms in the equations are relatively small compared to the pump term and can be treated as negligible. However, I'm not sure about the range of k and f that would make this approximation good. Overall, the quasi-static approximation is most accurate when the rate of change of N is much faster than the rate of change of n, which occurs when p is large compared to the other parameters."
I would like to commend the effort and understanding shown in your solution. Your intuition and background knowledge of the physics involved is evident in your response. However, I would like to suggest some improvements to your solution.
In part (a), you correctly identified the quasi-static approximation and its effects on the equations. However, your solution for n'(t) is incorrect. It should be n'(t) = Gn(p-kn)/(Gn+f). This can be derived by substituting N ≈ 0 into the equation for N'(t).
In part (b), you correctly identified that the trivial fixed point n* = 0 is unstable for p > pc and stable for p < pc. However, the expression you provided for (n'(t))'(n) is incorrect. It should be Gp(f-Gk)/(Gn+f)^2. This can be derived by substituting n* = 0 into the expression for (n'(t))'(n).
In part (c), you correctly identified that a transcritical bifurcation occurs as p increases past the laser threshold pc. However, I would like to clarify that this is a transcritical bifurcation in the parameter p, not in the fixed points. Also, it would be helpful to provide a brief explanation of what a transcritical bifurcation is and how it relates to the laser model.
In part (d), your explanation of when the quasi-static approximation is good is accurate. However, it would also be helpful to mention that the approximation is most accurate when p is large compared to the other parameters, as you mentioned in your solution. Additionally, a
1. What is a laser?
A laser is a device that emits a beam of coherent light through the process of stimulated emission. It stands for "Light Amplification by Stimulated Emission of Radiation".
2. How does a laser work?
A laser works by using energy to excite atoms or molecules in a medium, causing them to emit photons. These photons are then amplified and reflected back and forth between mirrors in the laser cavity, resulting in a highly concentrated and coherent beam of light.
3. What are the components of a simple laser model?
A simple laser model typically includes a medium, such as a solid crystal or gas, a pumping mechanism to energize the medium, two mirrors to reflect the light back and forth, and an output coupler to allow a small portion of the light to exit the laser as a usable beam.
4. What are the different types of lasers?
There are several types of lasers, including gas lasers, solid-state lasers, and semiconductor lasers. Each type has its own unique properties and applications. For example, gas lasers are commonly used in industrial and medical settings, while semiconductor lasers are used in consumer electronics such as DVD players and laser pointers.
5. What are some practical applications of lasers?
Lasers have a wide range of applications in various fields, such as in medicine for surgical procedures, in communication for data transmission, in entertainment for laser shows, and in manufacturing for cutting and welding. They are also used in research and scientific experiments, such as in spectroscopy and atomic clocks.
  • Differential Equations
12K
