What is the tension required to raise a crate using frictionless pulleys?
In summary, the problem involves a crate being pulled up using frictionless pulleys with specific masses. The tension required to raise the crate at a constant speed must equal the sum of the masses times gravity divided by two. Using Newton's second law, the correct answer is 214 N. The angle of the pulley is irrelevant and the general rule is to divide the weight lifted by the number of supporting lines in the pulley system to find the necessary force.
jamdr
I'm working on this rather simple pulley problem, and can't quite figure it out. It doesn't even involve acceleration. Could anyone help me out? Thanks.
Here's the problem:
A crate is pulled up using frictionless pulleys in the manner shown in the figure. The angle is 45 degrees. The masses are, for the small pulley, m1=3.5 kg, for the traveling pulley, M2=6.3 kg, and for the crate, MC=37.4 kg. What is the tension with which the operator must pull on the cable (assume the cable is of neglible mass) in order to raise the crate at a constant speed?
Here's the illustration.
There are two things going on here. Imagine the person pulling on the line for a distance of one meter. The line from pulley m1 to the person lengthens by x meters so the total line from point of attachment to pulley m1 decreases by x meters. Since the "travelling pulley", m2, stays at the midpoint of the line, its height and the height of the mass increases by x/2 meter. Now apply "conservation of energy". The crate, MC= 37.4 kg, so weight 37.4g Newtons, has raised by x/2 m so its potential energy has increased by (37.4g)(x/2) Joules. The "travelling pulley", m2= 3.5 kg so 3.5 Newtons weight, has raised by x/ m so its potential energy has increased by (3.5g)(x/2)Joules. The stationary pulley, m1, does not move- its potential energy doesn't change. The potential energy for the system has increased by (37.4g)(x/2)+(3.5g)(x/2)= (40.9g)(x/2) Joules. That means that that amount of work has been done by the man pulling on the line. Since Work= Force*distance and he has moved the line for x meters, he must have done xF= (40.9g)(x/2) Joules of work and so F= 40.9g/2= 20.45g N.
General rule: divide the weight lifted by the number of supporting lines in the pulley system: a total of 40.9g N weight was lifted by two lines: Force necessary is half the weight.
Since pulley m1 changes the direction of pull, the angle θ is irrelevant.
That works
Thanks for the reply. I think I follow your reasoning, although you did it differently than I did (I was trying to analyze the system only in terms of Newton's second law). The answer is correct, though. :smile:
I believe that the answer Halls gave is incorrect: he used the wrong M2 (which is 6.3 Kg, not 3.5 Kg).
In any case, using Newton's second law is an easier way to solve this problem. For the system (moving pulley plus crate) to be lifted at a constant speed, it must be in equilibrium: The upward force (which is 2T) must equal the downward force (M2+MC)g. So, the tension required is (6.3 + 37.4)g/2 = 214 N.
Correction
Thanks, Doc. The correct answer is indeed 214 N. I meant that the method Halls used to solve it was correct, although I went through the calculations and plugged in the numbers myself.
It is easier to use Newton's 2nd Law. I had tried this the first time, but arrived at the wrong answer because I thought I needed to take into account the small pulley (now I see that I didn't have to since it's attached to the ceiling). Thanks for everyone's help.
Related to What is the tension required to raise a crate using frictionless pulleys?
1. How does a pulley work?
A pulley is a simple machine that consists of a wheel with a groove around its circumference and a rope or belt that passes through the groove. When one end of the rope is pulled, the wheel rotates and can be used to lift or move objects. This is due to the principle of mechanical advantage, which allows a smaller force to be applied over a longer distance to move a larger load.
2. What is the difference between a fixed and a movable pulley?
A fixed pulley is attached to a stationary object, while a movable pulley is attached to the object being moved. In a fixed pulley, the direction of the force applied is changed, but the magnitude remains the same. In a movable pulley, the direction and magnitude of the force are both changed, making it easier to lift heavy objects.
3. How do you calculate the mechanical advantage of a pulley system?
The mechanical advantage of a pulley system can be calculated by dividing the load or weight being lifted by the force or effort applied. For example, if a 100 kg weight is lifted with a force of 25 kg, the mechanical advantage is 4 (100 kg / 25 kg = 4). This means that the pulley system reduces the force needed to lift the weight by 4 times.
4. Can a single pulley provide a mechanical advantage?
No, a single pulley does not provide a mechanical advantage as the direction and magnitude of the force remain the same. However, it can be used to change the direction of the force, making it more convenient to lift objects in certain situations.
5. How can you increase the mechanical advantage of a pulley system?
The mechanical advantage of a pulley system can be increased by adding more pulleys. Each additional pulley increases the mechanical advantage by the number of ropes supporting the load. For example, a system with three pulleys will have a mechanical advantage of 6 (3 ropes supporting the load x 2 because of the direction change at each pulley = 6).
