A sled is being pulled accross horizontal, snow covered ground
  • Thread starter Thread starter smaan
    Ground Horizontal
A 16-kg sled is pulled across snow by a 24 N force, reaching 2.0 m/s over 8.0 m. The sled's acceleration was calculated to be 0.25 m/s², and the normal force is 156.96 N. To find the coefficient of kinetic friction, the net force must be determined, taking into account both the pulling force and the frictional force. The frictional force can be calculated using Newton's second law, where the net force equals the mass times acceleration. The correct approach will yield the coefficient of kinetic friction once the friction force is accurately calculated.
smaan
A 16-kg sled is being pulled along the horizontal snow-covered
ground by a horizontal force of 24 N. Starting from rest, the sled attains
a speed of 2.0 m/s in 8.0 m. Find the coefficient of kinetic friction
between the runners of the sled and the snow.
I have found the acceleration of the sled by using the v^2 = v0+2ax. So, 2^2 = 2(a)(8), which gives me 0.25 m/s^2. I also calculated the normal force. Since it is a horizontal plane, it would be (9.81)(16) = 156.96 N.
Not to sure how to get the μFk from here.
Thank you for your time
How might you find the friction force acting on the sled? (Hint: Newton's 2nd law.)
If that is indeed the acceleration [I don't doubt you - I have just not checked your answer] you should know the net force, and thus how large the friction that opposes the applied 24N force.
Once you have the size of the friction force, you should be able to calculate the coefficient of friction, since you have the normal force.
Would the frictional force be F=ma? So would F=(16kg)(0.25m/s^2)=4N?
So then, μk=Fk/FN. So, since I found the normal force to be 156.96 N, the kinetic friction coefficient would be 4/156.96 = 0.022548?
Newtons second law, using the actual acceleration, gives you the net Force acting.
The applied Force plus the Friction Force [adding as vectors of course] give the net Force.
The answer you give here is not correct.
No. When you use F = ma, remember that F is the net force. So it's better to write it as: ƩF = ma.
There are two horizontal forces acting: The pulling force and the friction force. Set up an equation and solve for the friction force.
Once you solve for the correct friction force, then this method will give you μk.
