A spherical conducting shell in an electric field field
A spherical conducting shell placed in an external electric field will not have any induced charge on its inner surface if there is no free charge inside the shell. The external electric field is completely shielded by the conducting shell, resulting in zero electric field both within the metal of the shell and inside the hollow region. In a static situation, the electric field within the conductor must vanish, leading to zero charge density throughout the metal. Any charge that appears will be distributed on the outer surface of the shell to cancel the external field. Thus, the shell effectively protects its interior from external electric influences.
transparent
If a spherical conducting shell is kept in an electric field (say, from a point charge kept at some distance outside the shell), will any charge be induced in the internal surface of the shell? Also what will the field be like inside the shell? Thanks.
If the interior of hte sphere does not contain free charge (usually the case if we did not put it there intentionally), the outer metallic shell of the sphere will shield the external field, so that in the metal and inside the sphere there is zero net field.
Thanks. What about the charge? Will there be any charge on the inner surface of the shell? Also, how does the shielding effect work?
No. The shielding works this way: in static situation, there cannot be no currents in the metal, so electric field in the metal has to vanish. Due to Gauss' law, this also means there is zero charge density throughout the metal of the sphere. The only non-zero charge density can be at the surface and will be distributed in such a way so that it can completely cancel the external field.
Likes 1 person
Thread 'Colors in a plasma globe'
I have a common plasma globe with blue streamers and orange pads at both ends. The orange light is emitted by neon and the blue light is presumably emitted by argon and xenon. Why are the streamers blue while the pads at both ends are orange? A plasma globe's electric field is strong near the central electrode, decreasing with distance, so I would not expect the orange color at both ends.
  • · Replies 24 ·
