A strange wave function of the Hydrogen atom
omegax241
I am trying to solve the following exercise.
In a H atom the electron is in the state described by the wave function in spherical coordinates:
\psi (r, \theta, \phi) = e^{i \phi}e^{-(r/a)^2(1- \mu\ cos^2\ \theta)}
With a and \mu positive real parameters. Tell what are the possible values of the measurement of L_z, what is the probability that a measurement of L^2 gives the value 6 \hbar^2, and then what is the minimum value of an energy measurement.
First I've observed that m=1, so the only possible measurement for L_z is \hbar. (I'm pretty confident with this reasoning, but not so much.)For the other questions my idea was to rewrite the wavefunction as a linear combination of stationary states of the form \phi_{n,l,1}, but the problem is the square on the r part, and the fact that the angular part \theta is exponentiated.
In fact I've even started to ask myself is if necessary at all to find this decomposition to solve the problem, but nothing comes to mind.
Thank you for listening, every bit of help is appreciated.
To find the coefficient of a particular eigenfunction you do not need to completely decompose the wavefunction. Do you know how to do that?
I've had a look at this. I must admit I don't see how to tackle it. That wave function looks horrible. Sorry, I've no ideas either.
Yes, I should evaluate the product:
\langle \phi_{n, l ,m} | \psi \rangle
But suppose I want to tackle the second question, if a value of 6 \hbar is found for L^2 this means that l = 2, and then m = \pm 1 ; \pm 2 ; 0. So I should evaluate the coefficents​
\langle \phi_{n, 2, \pm 1} | \psi \rangle
\langle \phi_{n, 2, \pm 2} | \psi \rangle
\langle \phi_{n, 2, 0} | \psi \rangle
But how can I find a definite number with this n dependence ?
Likes vanhees71 and PeroK
You know that ##m = 1##. It's the variable ##n## that's the problem.
Likes omegax241
Doesn't parity tell you that an eigenstate of l=2 must be even? The wave function provided is odd.
Likes PhDeezNutz and vanhees71
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
