How Do You Calculate Deceleration from Two Segments of Motion?
  • Thread starter Thread starter Plantatree123
    Kinematics
To calculate deceleration from two segments of motion, the body travels 10m in the first segment in 1s and 10m in the second segment in 2.2s. The equations for motion under constant deceleration are applied, leading to two equations with two unknowns: initial velocity and acceleration. By summing the distances and using the known times, the problem can be approached effectively. Ultimately, the calculated deceleration is 3.4 m/s². The discussion emphasizes the importance of utilizing both segments' data to derive the solution.
Plantatree123
I am stuck with this task please help me.
1. A body is moving with constant deceleration while passing through path that contains two same parts and each one of them is 10m. The first part of the path, body passes for t1= 1s and the second part passes for t2=2.2s. Determine decelartion of the body!
I assume :
First part of the path : s1= vot1- (at12)/2
Second part of the path : s2= vt2 - (at22) /2
V = Vo -at1
I tried to sum s1 + s2 because the whole path is s = s1 + s2 and then to find acceleration but this was not good because I left with initial velocity. I tried it many times but each time unsuccessfully.
Plantatree123 said:
I assume :
V = Vo -at1
So far, so good.
Use the values given for the distances and times and you'll have two equations and two unknowns. Solve!
If you assume the same constant deceleration in both the paths It seems correct. You have two equation and two data to find ##a## and ##v_{0}##, try to solve the system ...
That's ok, but that's going from two pieces of information to one. As Doc Al says, you need to make the use of the fact that you know the two distances separately. Since in this case the two distances are the same, one interesting avenue to try is subtracting the two equations to produce another.
Plantatree123 said:
V = Vo -at1
That introduces yet another unknown, the velocity at the boundary. Can you think of another equation along these lines?
Ive found it ! Deceleration is a= 3,4 m\s2
Thanks everyone for help :))
