A Very, Very Interesting Problem
  • Thread starter Thread starter thedjoker
    Interesting
A diffraction grating with 150 lines per mm is analyzed for its interference pattern when illuminated by light of wavelength 275 nm. The problem requires calculating the number of bright spots, or maxima, that appear on a screen positioned at a distance from the grating. The solution involves applying the diffraction formula, which relates the wavelength, grating spacing, and the angle of diffraction. Participants are encouraged to show their work and reasoning rather than simply providing the final answer. Engaging in the solution process is emphasized as a key aspect of the discussion.
thedjoker
A diffraction grating has 150 "lines" per mm etched upon it. When light of wavelength 275 nm is normally incident upon the grating, how many bright spots appear on a screen a short distance away?:smile:
Please provide some attempt at the solution. We do not just provide answers here.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
