A weight of 15 lbs is suspended by a single rope
  • Thread starter Thread starter Nornh
    Rope Weight
A weight of 15 lbs suspended by a single rope experiences variable peak loads depending on how it is lifted and dropped. The conservation of energy can be applied to determine the velocity after a one-foot drop, but without a specified time frame, calculating the force is impossible. The characteristics of the rope, particularly its spring coefficient, significantly influence the peak load; a stiffer rope generates greater forces compared to a softer one. The discussion also raises the question of whether this scenario is akin to an earlier problem involving instantaneous changes, which would require infinite force. Understanding the dynamics of the weight's movement is crucial for accurate calculations.
Nornh
PROBLEM:
A weight of 15 lbs is suspended by a single rope. The weight is lifted 1 ft and dropped 1 ft.
What is the lb peak load on the rope?
There is not enough information to answer this question. One could do it in this way: Use "conservation of energy" to determine the velocity after the one foot drop. The velocity after the drop is 0 (or, if the rope is "springy" could be upward) so you calculate the change is speed. The force is the change in speed divided by the time in which that change took place.
You don't give a time so the last step can't be done. If you model the rope as a spring with given spring coefficient, then you could do this. A very "stiff" spring (high spring coefficient) will give a much greater force than a "soft" spring (low spring coefficient) so you definitely need to know the properties of the rope. Think of it as the difference between jumping off a cliff tie to a steel cable as opposed to a bunjee cord.
Is this the same problem as the one posted earlier with the "instantaneous" change (which would require an infinite force)?
Depends on how fast the weight is lifted or dropped, and how it is done.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
