Proving an Abelian Group with 2 Elements of Order 2 has a Subgroup of Order 4
In summary, to prove that an abelian group with two elements of order 2 must have a subgroup of order 4, one must show that the subgroup is closed under the group operation and that the inverses of all elements in the subgroup are also in the subgroup. This can be done by showing that the subgroup must contain the elements a, b, ab, a^-1, and b^-1, giving a total of five elements, and then showing that a and b have orders of 2, so their inverses must also be in the subgroup. This results in a subgroup of order four.
Prove that an abelian group with two elements of order 2 must have a subgroup of order 4
Let G be an abelian group ==> for every a,b that belong to G ab=ba.
Let a,b have order 2 ==> a^2 =e and b^2 = e. Since a belongs to G aa=a^2 belongs to G. Since b belongs to G bb= b^2 belongs to G. IE four elements ie order of a subgroup can be four.
It's not enough to say there are four elements in G to prove that there is a subgroup of order 4. (Plus since a2=b2=e, you've only shown there are three elements in G.) Think about what "subgroup of order 4" means. What do you need to show to say that a subset of G is a subgroup of G and that its order is 4?
Um, what four elements have you singled out? I don't see how saying a^2 belongs to G and b^2 belongs to G helps, since we already know that both are equal to e, which obviously belongs to G since G is a group (and that's a single element).
Well inorder to show something is a subgroup you have to show that it is closed under the operation and that if a belongs to the subgroup then a^-1 (inverse of a) belongs to the subgroup. but what i can't figure out is how to tie that into proving the sungroup has four elements in it. well wait. if a belongs to the subgroup, a inverse should belong there as well. the same goes for b and b inverse. so i guess that's four elements? atleast?
Again, you have to be careful here. If a^2 = e, what does this tell you about a^-1 (Hint: multiply both sides of the equation by a^-1)?
Suppose H is a subgroup that includes a and b. What other elements have to be in H?
that means a= a inverse which is not true
ab, a inverse and b inverse
Why not?
vela said:
Why not?
because in a group a(a^-1) must equal e. but if a^-1=a then a^2=e. ok so a should equal a^-1?
1. What is an Abelian group?
An Abelian group, also known as a commutative group, is a mathematical structure consisting of a set of elements and a binary operation that satisfies the commutative property, meaning that the order of the elements does not affect the outcome of the operation.
2. What is the significance of an Abelian group with 2 elements of order 2?
An Abelian group with 2 elements of order 2 is a special type of group that has only two elements, both of which have an order of 2 (meaning that when the element is multiplied by itself twice, the result is the identity element). This type of group is important in abstract algebra and can be used to prove various theorems and properties.
3. How do you prove that an Abelian group with 2 elements of order 2 has a subgroup of order 4?
To prove that an Abelian group with 2 elements of order 2 has a subgroup of order 4, you can use the subgroup criterion, which states that for a subset of a group to be a subgroup, it must contain the identity element, be closed under the group operation, and contain the inverse of each of its elements. By constructing a subset with these properties, you can prove that it is a subgroup of the original group with an order of 4.
4. Can this proof be applied to all Abelian groups?
Yes, this proof can be applied to all Abelian groups. The subgroup criterion is a general method for proving the existence of subgroups in any group, and an Abelian group with 2 elements of order 2 is a specific type of group that can be used to demonstrate this method.
5. What are some real-world applications of this theorem?
This theorem has applications in many fields, including cryptography, coding theory, and physics. In cryptography, it can be used to prove the security of certain encryption algorithms. In coding theory, it can be used to construct error-correcting codes. In physics, it can be used to study symmetries and conservation laws in systems with discrete elements.
