Why Do Different Objects Share Similar Moments of Inertia?
The discussion centers on the moment of inertia for various geometric objects, specifically a thin disk, a cylinder, and a thin hoop. The moment of inertia for these shapes is expressed as I = 1/2MR² for the disk and cylinder, while the thin hoop also shares this value when rotating about its diameter. The similarity arises from the mathematical integration of mass distribution, where the hoop can be conceptualized as a series of disks. The perpendicular axis theorem further supports this relationship by providing a framework for understanding the moment of inertia in planar objects.
  • Understanding of moment of inertia and its mathematical formulation
  • Familiarity with the perpendicular axis theorem in physics
  • Basic knowledge of integration and calculus
  • Concept of mass distribution in rigid bodies
  • Study the perpendicular axis theorem in detail
  • Explore the derivation of moment of inertia for various geometric shapes
  • Learn about the application of integration in calculating moments of inertia
  • Investigate the physical implications of mass distribution in rotating bodies
Physics students, engineering majors, and anyone interested in the principles of rotational dynamics and the mathematical foundations of moment of inertia.
Cha0t1c
Hello, I am a computer science major and Ex-Biology grad student, my knowledge in physics is humble, but I got a little curious when my professor derived the expressions of moment of inertia for different objects.
The moment of Inertia of a thin disk is 1/2MR2, but it is the same as the moment of Inertia for a cylinder and, surprisingly, the same for a thin hoop rotating about its diameter. So, in short:
I disk/perpendicular to axis of rotation = I Cylinder/perpendicular to axis of rotation= I thin hoop/through diameter
QUESTION:
How do we explain the similar moments of Inertia of the different objects?
My hypothesis concerning the moment of inertia of the thin hoop:
The hoop is rotating about its own diameter, if we take any point on the hoop and project its rotation on a plane perpendicular to the axis of rotation, we'll end up with a circle. Now, if we do the to every point on the hoop, we end up with a disk. Hence, the similar moment of inertia between the disk and the hoop!
Hi,
$$I\equiv \int r^2\, dm$$
Disk and cylinder are the same because it's the same integral.
You can also think of a cylinder as a pile of disks,
Hoop is a little different. For your scenario you still have to show that the thickness of the 'disks' is a constant ...
Or, you could consider that the hoop is a planar object and use the perpendicular axis theorem
  • · Replies 49 ·
  • · Replies 69 ·
  • · Replies 30 ·
