Absence of air in well holes eliminate change in pressure?
Sucking air out of an oil well after drilling a few feet and sealing it may not effectively eliminate pressure changes or prevent kicks due to the inability to create a complete vacuum. The hydrostatic pressure at significant depths remains largely unaffected by minor reductions in pressure at the surface. A kick can occur when drilling through varying rock densities, leading to sudden pressure increases that can damage equipment. The discussion references a similar question previously addressed, indicating ongoing interest in the mechanics of well pressure management. Understanding these dynamics is crucial for safe drilling operations.
ahmed11
if i sucked air out of an oil well after drilling a few feet and closed the hole by any means and continued drilling without allowing air in, will that eliminate change in influx and won't result in a kick?
or because i can't suck air completely out so the delta p will be really high?
hi there
trying to make sense of that ? specially this bit
what influx of what ? what kick ?
Dave
The hydrostatic pressure at the enormous depths of an oil well wouldn't be affected much by reducing the pressure of air in the top of a bore by just one Atmosphere (which is as much as you can 'suck').
I think that's what you are talking about?
davenn said:
hi there
Dave
Infux - I don't know.
kick - a pressure transient from the way down at the drill head. Can blow your pipes. I think it comes from plowing (drilling) through changes in porosities ( and densities I guess ) of rock. For example, more porous and the fluid inflow way down under ( maybe that is the influx ) can suddently increase the pressure at the bit and the pressure wave travels up the line to you and your machineray at the surface, and possibly up and down a few time before it dissipates. Probably more complicated that that.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
