Abstract Algebra mathematica add on
Jesssa
hey,
I have this group I've been trying to generate using the GenerateGroupoidByRelations[] function but it keeps giving me an error,
G = GenerateGroupoidByRelations[{a, b}, {a^4 == e, b^4 == e, a ** b ** a ** b == e, a^3 ** b ** a^3 ** b == e}, SizeLimit -> 60]
gives
GenerateGroupoid::size: The size of the set generated thus far exceeds the current value of 25 given by the option SizeLimit. (The elements generated thus far are shown below.)
It outputs a list of elements after this, but it depends on what i set the sizelimit too, if i set it to a large number ,it will spit out hundreds, if set it to 60 it will spit out 60
This group only has 16 elements which I found after an hour of todd coxeter,
Does anyone know how I could get mathematica to generate this group?
I don't know the answer, but I think mathematica isn't really good for such questions. I recommend that you look at GAP: http://www.gap-system.org/ Such questions can easily be solved there.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
