nebbish
- 18
Abstract Algebra -- no Sylow allowed
Please note Sylow's theorem(s) may not be used.
Using Theorem 1 as a tool, prove that if o(G)=p^{n}, p a prime number,
then G has a subgroup of order p^m for all 0\leq m\leq n.
Theorem 1:
If o(G)=p^{n}, p a prime number, then Z(G)\neq (e).
Theorem 1 uses the class equation to do the proof and I imagine that we are expected to use the class equation to do this exercise as well.
I can use the class equation to set up a proof by induction but my method fails because the class equation does not break G into smaller pieces if G is abelian.
Here's how my attempted solution goes (I basically pretend I'm only dealing with the non-abelian case):
Assume that the theorem is true for n = 1 and proceed by induction on n (it is trivial for
n=1).
In the following, p^{n_a} is the order of the normalizer of conjugacy class representative a (when the normalizer is smaller than G) and z is the order of the center:
The class equation is: p^n=z+ \Sigma \frac{p^n}{p^{n_a}}
Since G is non-abelian the largest value of p^{n_a} is p^j where
1 \leq j \leq n-1.
Then by the class equation, p^{n-j} \mid z. Then z = p^{n-j+k} where k < j because G is non-abelian. By induction, the normalizer of a, N(a), has
subgroup H with o(H)=p^{j-k-1}, and Z(G)H is a group
with o(Z(G)H)= o(Z(G))o(H) = p^{n-1}.
By the inductive hypothesis, Z(G)H has subgroups of the desired orders, i.e. Z(G)H has a subgroup of order p^m for all 0\leq m\leq n-1.
Thus G has a subgroup of order p^m for all 0\leq m\leq n.
The problem that I see of course is that I have not addressed the case where G is abelian and that throws off the whole induction.
For the abelian case, there's a little Cauchy Theorem I could use saying that G has a subgroup H of order p (normal because G is abelian), and from there I could infer that o(G/H)=p^{n-1}. However, I failed to find a bijection between G/H and some subgroup of G.
Theorem 1:
n=1).
1 \leq j \leq n-1.
