MrBondx
- 26
- 3
ThanksThe Electrician said:Read post #5
gneill said:Leave ##V_3## as ##V_3## for now! That way you don't have to carry around any complex digits through the initial simplifications. Don't be in a hurry to plug in numbers, especially complex numbers; That just gives more opportunities to make transcription and sign errors, and makes it more difficult to spot mistakes in the workings.
You should then have:
##\frac{V_1 - V_{20}}{Z_1} + \frac{-V_{20}}{Z_4} + \frac{-(V_{20} - V_3)}{Z_5} + \frac{V_2 - (V_{20} - V_3)}{Z_3} = 0##
which becomes, after distributing the signs:
##\frac{V_1 - V_{20}}{Z_1} - \frac{V_{20}}{Z_4} + \frac{V_3 - V_{20}}{Z_5} + \frac{V_2 - V_{20} + V_3}{Z_3} = 0##
Can you carry on from there to isolate ##V_{20}##? You should be able to reach a point where you have something like:
##V_{20}[## some terms ##] + [## more terms ##] = 0##
Then you can work on reducing the "some terms" and "more terms" down to individual complex numbers, since then all the variables in them will be known values.
Some sign errors snuck in. So no, not so good![]()
MrBondx said:In the first expression isn't the last part supposed to be (V4 - V3) / Z3 . How do we lose V4 to only end up with V2 and V3
I don't recall any V4 being defined. There was a V40, which was at the junction of Z3 and V2. As such, V40 is dropped in favor of using V2 which has a given value. There was also a voltage V30 defined to be the potential of the node at the top of Z5. But thanks to the supernode, it is replaced with V20 - V3.MrBondx said:In the first expression isn't the last part supposed to be (V4 - V3) / Z3 . How do we lose V4 to only end up with V2 and V3
gneill said:I don't recall any V4 being defined. There was a V40, which was at the junction of Z3 and V2. As such, V40 is dropped in favor of using V2 which has a given value. There was also a voltage V30 defined to be the potential of the node at the top of Z5. But thanks to the supernode, it is replaced with V20 - V3.
gneill said:Hah! I guess I took too long preparing my post![]()
MrBondx said:I'm coming up with
60 + j30 = V20(0.75 + j0.05)
V20 = 76.99 + j45.13
I = V20 / Z4
= (76.99 + j45.13) / -j5
= j15.398 - 9.026
if I compare to part a my j value seems off, where am I going wrong?
Gremlin said:Your 60 + j30 should be 67.07 + j30 - you're missing a V3 / Z5 and a V3 / Z3.
what is the matrix spreadsheet??ProfNut said:Hi I am stuck on part a of this question:
the 3 mesh equations i have are:
Mesh1:
2I1-j5I1+j5I2=120
Mesh2:
j5I1-j1I2-j4I3=-14.14+14.14
Mesh:3
-j4I2+4I3+j4I3=-120
I have tried to use the matrix spread sheet to find I1,I2 & I3. But my answers seem well out.
9.11E+00+j1.23E+01
4.18E+00-j8.04E+00
-8.89E+00-j1.69E+01
Any help would be much appreciated.
It looks to me like you're mixing current directions. You want to either sum all currents flowing into the node, or all currents flowing out of the node, and set the result to zero. Don't mix directions.brabbit87 said:im struggling abit with the nodal analysis. i think i have simplified the equation appropriately.
Equation with substitution for v30: ( v10 - v20/ z1)) + ( v20/ z4) + ( v20 - v3 / z5) + (v2 - v20 + v3/ z3) = 0
Thankou. Maybe being abit too careless. Will make another attempt.gneill said:It looks to me like you're mixing current directions. You want to either sum all currents flowing into the node, or all currents flowing out of the node, and set the result to zero. Don't mix directions.
For example, your first term: ( v10 - v20/ z1)) {which I assume to mean ( (v10 - v20)/ z1)): watch your parentheses to group operations appropriately!} represents a current flowing into the supernode at V20 through impedance Z1. But your second term, ( v20/ z4), represents a current flowing OUT of the supernode via Z4.
Check each of your terms and assure that they all represent currents flowing in the same manner, either into or out of the supernode, and not both.
I'm not so sure. What is wrong with v3 in my mesh 2 equation.gneill said:Check the sign of v3 in your mesh 2 equation. You appear to be writing a sum of potential drops, so...
you need to define which way your currents go...brabbit87 said:I'm not so sure. What is wrong with v3 in my mesh 2 equation.
Assuming clockwise current of circuit. It would be a negative voltage with positive voltage drops across the impedances?
I have defined which way my current goes in each mesh, clockwise. Or are referring to something else. I may have possibly missed?donpacino said:you need to define which way your currents go...
np. I just did not know... if that is the case then one of the Z terms in your mesh equations has the wrong sign...brabbit87 said:I have defined which way my current goes in each mesh, clockwise. Or are referring to something else. I may have possibly missed?
Apologies if i am being stupid with something
I apologise gneill, however i am still unsure.gneill said:Check the sign of v3 in your mesh 2 equation. You appear to be writing a sum of potential drops, so...
yesbrabbit87 said:I apologise gneill, however i am still unsure.
Is it just the 2nd mesh equation that i have incorrectly done?
My initial equation for the mesh 2, is that correct?donpacino said:yes
wow... your equation for mesh two is not correct.brabbit87 said:My initial equation for the mesh 2, is that correct?
Regards
donpacino said:wow... your equation for mesh two is not correct.
are you probing for someone to do just your work for you?
you have been told multiple times that there is a problem with your equation for mesh 2. Its hard to be more clear.
