AC circuit analysis -- mesh and nodal
187 replies · 63K views · last reply
In post #118 you said you had "got to the bottom of it". Does that mean that you derived a correct solution using mesh analysis? If so, wouldn't you think the value of I would be the same for nodal analysis? So why are you asking if the value you derived using nodal analysis is correct? Why don't you just compare the value you got with nodal analysis to the value you got with mesh analysis?
Do you see why I'm asking these questions? The very fact that you're asking about your nodal solution makes me wonder if you got the correct value from your mesh analysis.
What solution for the currents did you get with mesh analysis? What did you get for the value of I?
You don't have the correct value for V20, and probably not for V30 either although you didn't show what you got.
It makes it easier for those who would help you if you show your work.
Dear The electrician,
post 118 wasn t mine, i m currently offshore and my pc won t allow me to use the matrix for some reason (administrator issue, i m currently offshore), that s why i was wondering if the result was good or not. but i understand where you coming from i will post the analysis later on, thank you taking the time.
Sorry I didn't notice that there two different posters. As soon as you post your work, we'll help you out.
frenchy59 said:
Sorry made a mistake in calculation so i have :
V20(0.75+J0.05)=67071+J30
V20=91.6872+J33.875
V20/Z4=I
I=91.6872+J33.875/-J5
I=-6.7775+J18.3374
Your final answer is different to mine, looking at V20(0.75+j0.05)=67.071+j30, you have a sign different somewhere in the build up to this.
I don't want to post exactly what as I am new to the forum and I could be wrong and I am not sure what is acceptable to post in regards to solutions.
In the previous post to above you said this was for nodal analysis, but I would imagine I = I, which ever way we calculate it, so compare the results to your mesh analysis should help.
The notes aren't much help are they haha!
Also I couldn't get the spreadsheet to work on my work pc, used wolfram instead
This is a long thread, and correct answers have been given in early postings. So there should be no question as to what the correct answer is, but if recent posters can't get the correct answer and want help to find their error, they will have to post their work.
macca67, did you get the correct answer with both mesh and nodal analysis?
frenchy59, we'll wait for you to post your work.
Yeah going on the post on the first page I got it right (Thanks to some coaching by gneill).
Hi I am looking for guidance
I am happy with my 4 loops, however which is the best way to find current I1 I2 and I3 is it by deterimnents 3*3 or by a spreadsheet from what I have seen on this forum?
I'm not sure that you can declare a "best" method. Use whatever tools you have to hand and are comfortable with.
ok , i still have problem with spreadsheet but it look
R j I v
2 0 0 -5 5 0 120 0
0 0 0 5 1 -4 -14.14 + j -14.14
0 0 4 0 -4 4 0 -120
But unfortunately the result i get don t make sens
for nodal analysis i ve got
(V1-V20/Z1)+(-V20/Z4)+(-(V20-V3)/Z5)+(V2-(V20-V3)/Z3)
-V20((1/Z1)+(1/Z4)+(1/Z5)+(1/Z3))+((V1/Z1)+(V3/Z5)+(V2/Z3)+((V3/Z3)=0
33.535+J33.535/J5
I=-6.707+J6.707
R j I v
2 0 0 -5 5 0 120 0
0 0 4 0 -4 4 0 -120
LOOK BETTER WITH SPACES
trying to put my spreadsheet up but when i post it it cancel the spaces sorry
Can the result I in nodal analysis can be -7.24761+j25.4258
This is not going well!
If you place text inside a pair of [CODE] ... [/CODE] tags it will prevent the compression of spaces. (You can find CODE under the + on the menu bar.)
It will then preserve spacing, as here:
Code:
1       3.14159          2.71828
A bit messy, but that's the best we can do, I believe.
(Otherwise, of course, you could save as a jpeg or take a screenshot and then attach that image here.)
brabbit87 said:
Thanks for the help, for some reason. the spreadsheet given to me just is not calculating the mesh currents. i have tried an internet calculator and it calculates it just fine.
Hi, I am working on this problem at the moment and experiencing the same problem I think you and many others had with the spread sheet. Do you mind if I ask which online calculator you eventually ended up using to get your results ??
gneill said:
Leave ##V_3## as ##V_3## for now! That way you don't have to carry around any complex digits through the initial simplifications. Don't be in a hurry to plug in numbers, especially complex numbers; That just gives more opportunities to make transcription and sign errors, and makes it more difficult to spot mistakes in the workings.
You should then have:
##\frac{V_1 - V_{20}}{Z_1} + \frac{-V_{20}}{Z_4} + \frac{-(V_{20} - V_3)}{Z_5} + \frac{V_2 - (V_{20} - V_3)}{Z_3} = 0##
which becomes, after distributing the signs:
##\frac{V_1 - V_{20}}{Z_1} - \frac{V_{20}}{Z_4} + \frac{V_3 - V_{20}}{Z_5} + \frac{V_2 - V_{20} + V_3}{Z_3} = 0##
Can you carry on from there to isolate ##V_{20}##? You should be able to reach a point where you have something like:
##V_{20}[## some terms ##] + [## more terms ##] = 0##
Then you can work on reducing the "some terms" and "more terms" down to individual complex numbers, since then all the variables in them will be known values.
Some sign errors snuck in. So no, not so good :frown:
Hi, I am trying to understand and work my way through this question using the info posted in this forum. Its very useful for me but a quick question. How does ## \frac{-(V_{20} - V_3)}{Z_5}## become ##\frac{V_3 - V_{20}}{Z_5}## ? I can't understand how it went from 20-3 to 3-20
The sign outside the parentheses gets distributed over the contents of the parentheses (so the signs of the terms in the parentheses get reversed).
Ok i see this now in my working out, thanks
Hi Gneill, can you recommend any good reading material on AC circuit nodal circuit analysis with complex numbers? I have been trawling the net searching for examples incorporating the super node as in part b) but have yet to find anything!
I would like to try and fully understand the method before I go ahead and use it.
Many thanks
Many thanks
Hi GeorgeSparks, I can't think of any particular materials off hand. You might go looking for mesh analysis examples and pick out ones where there are voltage sources between nodes. Usually that always leads to a supernode situation. You can then compare the mesh analysis results to nodal analysis results to check your attempts.
Hi guys don't want to sound silly but for the mesh and Nodal analysis answers for current I have the real part is identical yet the imaginary j current value looks to be off by about 1.
I have used the spreadsheet shown in earlier posts for my mesh analysis and for the latter nodal I am sure is correct due to using full numbers avoiding rounding errors, the only other idea I have would be to solve the three simultaneous equations manually, does anybody have any ideas? I know I am being a little vague without showing any working haha.
Or can anyone recommend a good online calculator to confirm my spreadsheet readings?
Thnks in advance
If both of your answers are identical and off by the same amount it suggests that something is off in the input data.
For the Mesh analysis I end up with and answer for I = -9.152 + j17.275 this was calculated from I1-I2 From the complex matrix ((16.8117-j22.8805)-(25.9639-j40.1559)) all mesh analysis was done in a clockwise direction.
For Nodal analysis I simplified down and ended up with a result of 9.152+j18.337. My mind is boggled, the first results real terms for mesh analysis I can change d/t direction of current into Z4 based on my initial loop calculations as for the Nodal analysis I have calculated the current based on the voltage I have worked out at Node through Z4 which was 91.68725814+j45.75850158 / -j5. I am a little stumped, the only thing I can think is that the spreadsheet is a bit of a mess although I have looked through it several times and I am pretty happy with the input data (apart from it not allowing you to set 0 values instead you must input some values as 0.00001 but surely this couldn't have changed the imaginary term by over 1).
So your mesh analysis work looks fine. Your current is correct (signs included): the real part should be negative as you've found.
For the nodal analysis, the real part of your node voltage is incorrect. Multiply the current you obtained via mesh analysis by Z4 to see what value you should be getting for the node voltage.
Hi gneill,
I am still struggling with this, I calculated back as you said and ended up with a node voltage that of -86.3754311 + j45.7609738. I am still struggling to get the real term based on current circuit values given for the question. I end up with 67.07106781+j30 = (300-j20V/400) which gives me 91.68725814+j45.75850158 or 52.92893219+j30 = (300-j20V/400) which gives me 72.91451177+j44.50698515 based on my current calculations I am a little stuck to say the least... I have been through and recalculated numerous times now to ensure there have been no typos this has got me thinking that maybe the value for part a mesh analysis (the imaginary term) must be off somewhere when calculated using the spreadsheet. Hopefully I will manage to get to the bottom of it haha...
Well, the value you reported for the current from your mesh results, I = -9.152 + j17.275, is good.
You may have to break down and show us your node equation.
gneill said:
Okay, it was a bit strange at first seeing all those equals signs in the LHS expansion until I realized you were just breaking out the individual terms. I followed your work and found everything okay up to the very last line. Check that final calculation.
Ahhhhhh how frustrating! Haha I was soo bloody close albeit for one final mistake. That has had me stumped for the last few days thank you very much for the guidance
