AC motor load torque calculation
The discussion revolves around the calculation of load torque for an induction motor when connected to a cylindrical flywheel. Participants explore the relationship between motor torque, load torque, and the operational characteristics of AC induction motors, particularly in the context of electric drives.
  • Roman questions how to calculate the load torque of a flywheel to select an appropriate induction motor.
  • Some participants suggest that the torque required will include aerodynamic drag and bearing losses, while others emphasize that the motor will not accelerate until the load torque equals the motor torque.
  • Averagesupernova describes the flywheel as a "constant torque" load and seeks a general formula for torque calculation.
  • Another participant clarifies that no torque is required to maintain a constant RPM on a flywheel, except for friction and windage losses.
  • There is a discussion about the effects of load on motor speed, with some asserting that AC motors will adjust torque to maintain RPM under varying loads.
  • Participants mention the importance of moment of inertia in calculating the torque required to accelerate the flywheel.
  • There are differing views on whether the motor will continuously speed up without load, with some asserting that it will not.
  • Concerns are raised about the size of the flywheel affecting the motor's ability to reach nominal speed during startup.
Participants express multiple competing views regarding the relationship between motor torque, load torque, and speed regulation of AC induction motors. The discussion remains unresolved, with no consensus on the exact calculations or principles governing the operation of the motor with the flywheel.
Some participants note the need for clarity on the dimensions and mass of the flywheel, as well as the implications of different types of motors on performance. There is also mention of the moment of inertia and its role in torque calculations, but no definitive formulas are agreed upon.
RomanU
Hello!
Not sure whether it's a right place to post. My question is from a field of electric drives.
I can't figure out how to choose an induction motor for a certain load.
Load is a simple cylindric flywheel fitted directly on a rotor. Flywheel has a known mass and dimensions. I know that a motor would accelerate until it's torque will be equal to the load torque. So to select an appropriate motor I need to know it's torque rating(torque at ). The question is how to calculate the load torque of a flywheel?
Excuse me for my English.
Regards
Roman
Well the torque will be whatever aerodynamic drag you have on the cylinder and the bearing loss. But, if you have an AC induction motor it will NOT accelerate until the load torque = motor torque. AC induction motors have their speed regulated by line frequency. Once this machine is up to speed is there any other load besides the bearings and air friction? What are the dimensions of the cylinder?
I think a motor will accelerate until it's torque equals a load torque. And the speed therefore depends on the load (assuming that frequency and voltage remains the same).
Below is an illustration. Several motor torque-speed characteristics are shown there. This cylindrical flywheel I described is a "constant torque" load i.e. torque doesn't depend on the speed rotation (black line in the picture).
The only thing I can't understand is how to calculate this load torque.
Averagesupernova: Cylinder may have any diameter, height and mass. I need a general formula to calculate a torque in order to select an appropriate motors.
You are correct in stating that a motor speeds up until its torque equals the load torque. But no torque is required to maintain a constant RPM on a flywheel (excepting for friction and windage). Flywheels are used to supply high instantaneous torque to a load, while the motor is used to replace the flywheel energy lost. A typical application of a motor flywheel combination is for an air compressor, or a motor flywheel alternator system, when the alternator output is pulsed. In these cases, the motor needs enough torque to speed up the flywheel from the minimum to maximum RPM between compression strokes.
You both are INCORRECT in stating that a motor (at least AC induction motors, and AC is in the title of this thread) will speed up until load matches motor torque. An AC induction motor will not contiuously speed up with no load. As long as the load torque is within the motors specs, it's speed will be regulated within a few RPM of nameplate spec'd speed regardless of speed. Universal series wound motors such as a portable electric drill motor are a different story. They require some sort of load to prevent them from running wild.
So Romanu, you tell US what type of motor you want to use.
I was talking about AC induction motor, asynchronous motor in other words.
Averagesupernova, I can't agree with you. AC motor speed depends on: voltage, frequency, and a load. Changing any of them leads to a change in speed.
As far as I know without a load a motor will speed up until it reaches the noload point (closer to the horizontal axis on the graphic). Motor won't continiously speed up because it's rotor itself is a load.
I'll state a problem in other words:
How to find out mass and dimensions of the flywheel (a cylinder) so that a motor will be running at nominal speed?
I know how to do it with other types of loads: hoisting, belt conveyor, but not with a simple cylinder on the shaft. :rolleyes:
Now are you talking about a change in speed of a few RPM or what? I will admit that much. But a 20% change in RPM from load to no load is NOT an induction motor or is a damn poor one.
I think you better have a read here: http://en.wikipedia.org/wiki/Induction_motor
The greatest torque on the motor will be in acting against the angular inertia of the load. This is greatest at omega_0. You may want a motor with a significant start-up phase.
Since we don't even know how large this 'flywheel' is, it's hard to say what type of motor to use. I have several bench grinders with a grinding stone on each end. I'm pretty sure one of them is 1/3 HP 3500 RPM motor. I suspect split phase, not capacitor start.
RomanU, you asked: How to find out mass and dimensions of the flywheel (a cylinder) so that a motor will be running at nominal speed?
The point is, there is no special how to at all. A flywheel is no load in the sense of taking power away from the motor (it stores energy, so it does not remove energy from the motor), and thus requires no energy at all, other than the very small amount consumed in its bearings.
About the only concern is to avoid putting too large of a flywheel on the motor, one that will prevent the motor from coming up to speed quickly during startup. If startup is dragged out, the high currents associated with start up can cause overheating in the motor. During startup, the motor is supplying power to the flywheel bring it up to speed. It is only after the motor and flyhweel are up to steady operating speed that the flyhweel takes no operating power from the motor.
With a large flywheel, a small flywheel, a fat flywheel, or a skinny flywheel, or no flywheel, the induction motor is going to run very close to rated speed when there is no load on the motor.
Ok. Thanks a lot, Dr.D. Now everything is clear to me with a flywheel i.e. it's no load.
Averagesupernova, thanks for the wikipedia link. But where is it stated that RPM doesn't depend on a load torque?
I know the Equation of motion: dw/dt = (Te-Tl)/J
I might be wrong, but doesn't it mean that acceleration stops at the moment when Te=Tl (motor torque = load torque)? As you guys clarified a flywheel is almost a zero load (low torque), that's why motor runs at speed close to synchronous. But if there is load torque RPMs change. Am I right?
With an AC induction motor, when the load increases, torque produced by the motor will increase to maintain RPM. When the load decreases, the torque produced by the motor will also decrease so the RPM is somewhat constant.
This occurs from the amount of "magnetic slip" of the rotor and the driving phase or phases. The rotor must lag the current by some amount for the motor to run. The further the rotor slips from that range, the higher the induced current and magnetic field. This property keeps RPM somewhat constant with varying torque to match the load, only fast load variations cause entire phases to slip, the flywheel is there to store energy during those periods.
bipolar, Thanks, I was wrong than.
It isn't very intuitive, especially when working with different types of motors, where the formula you posted for speed is correct.
I scratched my head the first time I saw the internals of one. I took it as handwavium proof that Physics works at the time.
Some of these posts might sound a bit misleading. There is a certainly energy, converted from the line, through the motor, to kinetic energy stored in the the flywheel. The rotor itself will also have stored kintetic energy.
Are you using single phase or three phase power?
3 phase supply.
Somehow I lost track of this thread.
The quantity you are looking for is called moment of inertia. It serves the same function as mass in the equation F=ma
Momentent of inertia,
I = \int r^2 dm
F=ma is replaced with
T=I\alpha
T is the torque and \alpha is the angular acceleration. \alpha = d\omega / dt. \omega is the angular velocity.
Phrak, I think this is in error, at least to some degree.
The greatest motor torque will exist when working against the greatest combination of inertial load (I*alpha) plus load torque. I think you assumed that the motor is starting with no load, and that may, or may not, be a good assumption.
I assume the motor is reasonably sized for the load, and that the flywheel is more than decoration. As you might be aware, under these conditions start current is larger than run current. Current is a close measure of torque. I also assume the rather expected condition that the angular momentum is not being reversed... This is the engineering forum, after all.
I don't know the load. I've been assuming something like a flywheel, clutch and forge.
Nothing I read specified the load, so I agree that the load is unknown. I simply wanted to point out that the load torque needs to be included in the equation when making statements about the maximum motor torque situation.
I'm not sure I understand what the comment, "This is the engineering forum, after all," means. In engineering, do we not encounter just about all kinds of situations?
How is torque characterized as a function of slip frequency, that's what I want to know. I haven't delt with induction motors before. It's starting to bother me. I thought wikipedia would save me, but the article is kinda stoopid.
RomanU answered the matter of torque as a function of slip frequency pretty well with the plot in #3 above. There the abscissa is running speed, but if you take synchronous speed - running speed you have slip frequency.
As that plot shows, there are all sorts of different curves possible, depending on the motor design.
I see. Then you can tell me how torque varies as a function of slip frequency for a 3 phase motor.
The analytical expression for motor torque as a function of slip is fairly complicated and contains all sorts of design parameters that usually are not readily available unless you are the motor designer.
If you really would like to pursue this, I would recommend the rather excellent textbooks by P.C. Krause out of Purdue. I worked through his stuff a few years ago and did some motor simulations that worked out quite well. The problem, always, is to know the motor parameters. There are tests that can be performed on an existing motor to estimate the parameters, but this is only after the machine exists and is in your hands; this is usually long after you want the information. Krause gives some typical machine parameters, and I used those for some papers that I was writing, but they would not be valid for any particular piece of machinery.
One thing I should mention about getting into this stuff is this: You will find out a lot more than you ever wanted to know. You cannot find out simply how torque varies with slip. You will also find out how all of the winding currents vary as well, all six of them, and that will usually mean simulating at least 7 variables as functions of time. It is pretty interesting to observe, and you can learn a lot, but it is not simple or neat.
Im sure it's not rocket surgery.
rocket surgery?
i think it is related with different kinds of ac motors.
Sizing the motor has two issues--acceleration time (depends on inertia) and load torque.
Yes, your system has load torque. In this case it is the friction and air-resistance of all rotating parts--bearings, fans, all rotating surfaces. Once runing, the motor will probably run very close to synchronous speed, being relatively unloaded. Read on.
One key problem is rotor heating during start-up. Induction motor rotors get hot during the start process, and can overheat when inertia makes it a long time. Generally, if your start-up is a few seconds you should be OK for most standard motors. For samller, off-the-shelf motors, even 10 seconds is probably OK.
The mfr usually has info like this if you give them the inertia and motor you are considering. In the end, your motor size may be determined by the acceleration process, and be over-sized for the continuous steady state, essentially lightly loaded to just maintain speed--not good for energy efficiency, hence the challenge of this application.
RomanU said:
Hello!
For concerned formula about simple flywheel torque you can refer to similar discussion in http://electrical-riddles.com ( Machine riddle No.24)
The thread addresses the direct drive of the flywheel with an AC motor. With a direct drive, the AC motor must accelerate the flywheel to motor synchronous speed before the motor overheats and, presumably, motor controls shut down the motor.
There is the potential to install a slip clutch or fluid coupling between the motor and flywheel. The designer specifies the time to get the flywheel to speed and selects a motor with full speed torque that produces the acceleration necessary to accelerate the flywheel within the specified time. The designer selects a suitable slip clutch (or fluid coupling) to transmit the torque from the motor to the flywheel with the motor at full speed while the flywheel accelerates. With the motor running at full speed and load, if it is rated for continuous service, the time to get the flywheel to speed is unlimited.
  • · Replies 18 ·
