donorcard
- 2
Imagine a mass attached to a spring, equivalent to a vehicle suspension system, where the mass we are considering is the unsprung mass of the wheel/axle assembly. We are told the unsprung mass is given an instantaneous acceleration of 50m/s². We are given the spring constant of the suspension springs (k = 500kN/mm) and we are given the mass of the wheel/axle assembly (m = 200kg). The system is assumed to be undamped.
I am trying to find the force which is exerted by the spring upward onto the vehicle body.
This is directly proportional to the compression of the spring but as I see it I just cannot make it work. Conservation of energy seems best suited, however I require the velocity of the wheel assembly (for ke = ½mv²) which I do not know. I have no time step increment with which to work out the velocity either.
The acceleration of the wheel/axle assembly is specified in a load case. The problem as I see it is relating this acceleration to the deceleration caused by the spring. I am hopefully just missing something but this problem really has me stuck. If the spring weren’t there then the force on the vehicle body would be a simple F = ma where the acceleration is 50m/s² I think, but this is a much worse than real case.
The mass is accelerated (say +ve direction) at the 'start' of the action and is immediately deccelerated (-ve direction) by the spring. But how this relationship is expressed I can't fathom.
Any advice or views are appreciated, thank you.
