Acceleration due to gravity help
To determine how long it takes for a 1kg mass to fall 2m on the moon, the acceleration due to gravity is calculated using the formula g = (m)(G)/r^2, yielding approximately 1.58m/s^2. However, the correct value for the moon's gravity is around 1.62m/s^2. To find the time of fall, the equation x = v₀t + 0.5at² should be used, where 'a' is the acceleration due to gravity. The gravitational constant G was provided to help calculate the moon's gravitational acceleration, which is essential for solving the problem. Understanding these concepts is crucial for accurately applying Newton's laws in this context.
sheevz
acceleration due to gravity help!
PROB: How long would it take for a mass of 1kg to fall a distance of 2m to the surface of the moon?
G=6.673*10^-11 Nm^2/kg^2
R of moon = 1.76*10^6m
m of moon = 7.35*10^22kg
i started by finding the acceleration due to gravity by using g= (m)(G)/r^2
(m=mass of moon, G as the gravitational constant, r= radius of moon)
finding that g is 1.58m/s^2
now i am lost in what formula to use to get the displacement of this object?
Check your acceleration due to gravity for the moon, it should be ~1.62m/s^2
To solve for time t, use the formula x=v_{0}t+\frac{1}{2}at^2
ok i don't know if this is a type o or not but yes the acceleration due to gravity for the moon is ~1.62m/s^2 but in this prob, the radius is given @ 1.76*10^6 thus giving an acceleration due to gravity @ ~1.58m/s^2
and in using the above formula you gave me, X=Vot+.5at^2
is Vo my accel due to gravity on the moon and a my G constant? why in the original problem was G given to me, is it necessary in this? (probably a stupid question)
Those pieces of data were given to you so you could work out the acceleration due to gravity, to sub into the formula konthelion gave to you. Obviously you did this through Newtons Universal Law of Gravitation. After we have the force, Using Newtons Second Law we can have the acceleration. We can take the Force and acceleration to be practically constant, because the change in the value of r in the Universal Gravitation Law changes by one 1m, very small in comparison to the radius of the moon. Although yes, it is true it is not exactly constant.
