Acceleration of a gas into a vacuum
When a gas is released into a vacuum by removing a divider, the behavior of the gas flow is debated. One perspective suggests that as the gas volume decreases, the flow speed may slow down due to reduced pressure. Conversely, the vacuum's pull remains relatively constant, potentially keeping the gas's exit speed steady. The discussion highlights uncertainty about whether the gas acceleration increases, peaks, or remains constant as it enters the vacuum. Ultimately, the dynamics of gas flow into a vacuum involve complex interactions between pressure and volume changes.
Ron Spencer
Set up: Gas on one side of a divider and an infinite vacuum on the other.
Question: When you remove the divider, over time, does the gas increase in acceleration, does it peak and then decrease or does it remain the same as the gas enters the vacuum/ leaves the side opposite the vacuum?f
Thanks
Thanks
What are your thoughts on this?
What does this mean?
What I meant was, does the flow of gas into the vacuum go faster, stay the same or slow down over the time it takes for it to flow into the vacuum. I hope that is clear. If not, please let me know and I'll try again.
Well...its been a long, long time since I studied physics in college and frankly, I don't remember much theory. Within those parameters my thought is that, as the amount of gas in that chamber decreases I'd expect the speed that it flows into the vacuum to slow.
On the other hand, the "pull" of the vacuum, while slightly reduced by the introduction of the gas (slightly reducing the quality of the vacuum), will continue unchanged. If this is true then the speed of the gas leaving its chamber should remain constant. As you can see, I am torn on which is the correct analysis.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
