Acceleration of a revolving ball
  • Thread starter Thread starter bumblebeeliz
    Acceleration Ball
A 150-g ball revolving in a horizontal circle of radius 0.600 m completes 2.00 revolutions per second, leading to confusion regarding the period (T) calculation. The period is derived from the frequency, where T = 1/f, resulting in T = 0.500 s for one revolution. The centripetal acceleration can be calculated using the formula F = ma = mv²/R, where v is determined by v = 2πr/T. The discussion highlights the importance of maintaining significant digits and understanding the relationship between frequency and period. Clarity on these concepts is essential for accurate calculations in physics.
bumblebeeliz
A 150-g ball at the end of a string is revolving uniformly in a horizontal circle of radius 0.600m. The ball makes 2.00 revolutions in a second. What is the centripetal acceleration?
T = 1/f
v = 2\pir / T
I know the answer to this question because its an exercise but I am confused with the "T" equation (Period equation).
v = 2\pir / T
v = 2(3.14)(0.600m) / (0.500s)
How did we get the 0.500s?
T = 1/f
v = 2\pir / T
v = 2\pir / T
If in one second, the mass completes two revolutions, how long does it take for it to complete one revolution?
The relationship between the frequency (How many occurrences per unit of time) and the period (How long it is between one occurrence and the next) is:
f=T^{-1}=\tfrac{1}{T}
From the statement of the problem. If the ball makes 2 revolutions in one second, how much time does it take to make one revolution?
F = ma = m*v^2/R
cancel the m's to get a formula for acceleration.
There is an alternative one where v is replaced by 2*pi*R/T
so basically:
f = 2.00s -1 = 0.500s.
I think the extra zero's confused me.
bumblebeeliz said:
so basically:
You got the right answer numerically, but you got it by confusing the frequency. The correct expression for the frequency is
f = 2.00 \: \frac{1}{\text{sec}},
while you seem to have used
f = \frac{1}{2.00 \:\text{sec}}
and then fudged the units in the result.
They shouldn't. You should always keep the right number of significant digits in your calculations.
bumblebeeliz said:
so basically:
Like tms said, the dimensions for frequency are [T]^{-1}, and its units in the MKS system are \tfrac{1}{sec}\equiv 1 Hz
1 Hz (1 Hertz) is defined as a frequency of 1 per second.
