Acceleration of a Train Problem
A train slows from 90.0 km/h to 50.0 km/h while rounding a curve with a radius of 150 m over 15 seconds. To calculate acceleration, both radial and tangential components must be determined. The correct conversion of speeds from km/h to m/s reveals that 90 km/h equals 25 m/s and 50 km/h equals approximately 13.89 m/s. The tangential acceleration is calculated as 0.74 m/s², while the radial acceleration is about 1.29 m/s², leading to a total inward acceleration of 1.48 m/s². The discussion emphasizes the importance of accurate unit conversion and the calculation of both acceleration types to solve the problem effectively.
Husker70
A train slows down as it rounds a sharp horizontal turn, slowing from
90.0 km/h to 50.0km/h in that 15.0s that it takes to round the bend. The
radius of the curve is 150m. Compute the acceleration at the moment the train
speed reaches 50.0 km/h. Assume that it continues to slow down at this time at
the same rate.
Find the radial and tangential accelerations then get total acceleration. Direction
will be tan-1 of those. I've tried to start but my numbers don't seem to be
right. I've drawn a sketch.
Thanks,
Kevin
the same rate.
Thanks,
Kevin
Please do post what you have calculated. What you say seems perfectly right to me.
First I find the velocity by taking 50.0km/h - 90.0 km/h / 15s
I converted the km to 833.3m/s - 1500m/s/15s
I get velocity to be -44.4m/s
I used the radial acceleration equation (-44.4m/s)2 / 150m to get 13.14m/s2 inward.
I'm not sure how to get the tangential from here.
Thanks,
Kevin
Thanks,
Kevin
You made an error converting from Km/h to m/s
90 Km/hr= 25 m/s
50 Km/hr=13.8889 m/s
a(tangential)=(25-13.8889)/15
a(radial)= v^{2}/r where v=13.8889 an r=150
I'm not sure where my conversion came from
I get a tan acc to be .74 m/s2
I get a radial acc to be 1.2860 m/s2
I get 1.48 m/s2 inward acceleration by squaring the acceleration and then
getting the square root.
For angle is the tan/radial or is the radial/tan to figure angle?
Thanks for your help. I'm understanding this a lot better.
Kevin
