Acceleration of mass on an incline plane
A 17 kg block is pushed up a frictionless incline at a 31° angle with a horizontal force of 100 N. The initial calculations incorrectly assumed the component of the force along the incline exceeded the applied force, leading to confusion. The correct approach requires considering the weight component acting down the incline, which must be subtracted from the applied force to find the net force. The net force should account for the gravitational component, resulting in a downward acceleration of the block. Ultimately, the block will slide down the incline with an acceleration of 0.11 m/s².
gergerger
A horizontal force of 100 N pushes a 17 kg block up a frictionless incline that makes an angle of 31° with the horizontal.
Find the acceleration of the block.
F = ma
F_g = mg
Cos31 = 100/(component of force along plane) --> 100/cos31 = F --> F = 166.77N
Then I used this in my F = ma equation producing.
(116.77)N = (17)kg (a)
a = 6.86
This is the wrong answer.
F = ma
Fg = mg
the component of the force cannot be greater than the force itself. Recheck that equation.
(166.77)N = (17)kg (a)
a = 6.86
What happened to the component of the weight acting along the plane?
your second relevant equation is wrong (how can Fg=mg or F=m unless a=1?)
and the first step of the soln is also wrong...
how come component surpasses the force itself?Then solve(without forgetting weight components)...EDIT:: maybe me and phantomjay answered in quite near time gaps!
@Jay, Firstly, the force was already broken up, so yes the component of the force in the direction of the plane can indeed be bigger than the force in the x direction. I'm not sure what to do about the component of weight, that's rather why I posted the question. You answered nothing.
@Legend. Please, don't post where you have nothing useful to say. It isn't F times g, it's F subg meaning the component of force that is caused by gravity is equal to the mass of an object times acceleration due to gravity. Please, say no more. /facedesk
Gegerger: First - copping an attitude is not a good way to get help. Second, your initial post was, apparently, not clear - as legend, Jay, and I all seem to have understood the problem in the same manner. Third - your math is simply wrong in the last step - I'm not sure how you got a value of 6.86. Maybe you input 116.77, as opposed to 166.77?
we don't give answers here, only help, to those who want it.
Chill, you made an error denoting F_g as Fg. So be it. I've done it many times. It happens to the best of us.
About that help thing... Where is it exactly?
Oh, and whoever said that my math was wrong, it was... sort of. I did use 116.77 in my calculations and that is the right number. I wrote it wrong in the original post. /goes to fix
By help, we point you in the right direction. We don't do your work for you.
Now, to clear everything up, please describe the coordinate system you are using so we can all get on the same page.
Wow... Was going to help you but when I read this I don't want to waste my time. Way to treat the ones that are trying to help you do your freaking homework.
@Inferior, then why post? Gtfo already. Anyway, I didn't use a coordinate system jhae. If you have a suggestion about how to use one, please explain. ;)
Perhaps it's time for you to rethink your participation on this forum, gergerger.
I'm sorry, but did no one realize he had his equation for cosine upside down, or is that what PhanthomJay was trying to imply when he said "recheck that equation"? I just thought it might seem a little more straightforward of an approach to point out his error.
Also, as far as the answer goes, don't forget to include the component of the object's weight acting down the plane when you calculate your net force. The net force should be the difference between the 85.7N push parallel to the incline and the parallel component of the weight (170Nsin31, 87.6N). The block in fact should slide down the incline, with an acceleration 0.11 m/s/s.
The component of the 100N force acting into the plane only increases the normal force and does not cause it to accelerate into the inclined plane. If it were a real incline with friction, however this "perpendicular" component would increase the force of friction as well, which would also be included in your net force. Did that help at all? Are you remembering to turn your head sideways and redefine "horizontal" and "vertical"?
