Rocket Car Acceleration Analysis
A rocket car designed to break the land speed record must not exceed an acceleration of 5g, with a total mass of 6000 kg, including 2000 kg of fuel. The fuel is expelled at a constant speed of 900 m/s and is consumed over 15 seconds, resulting in a change in momentum of 120,000 N. The initial acceleration of the car, calculated using the rate of change of momentum, is 20 m/s². As the fuel is used, the final velocity of the car is determined to be 450 m/s using conservation of momentum, although this answer was questioned by some participants. The discussion also introduced the rocket equation for a more accurate calculation of velocity changes during fuel consumption.
songoku
A rocket car is developed to break the land speed record along a salt flat in Utah. However, the safety of the driver must be considered, so the acceleration of the car must not exceed 5g (or five times the acceleration of gravity) during the test. Using the latest materials and technology, the total mass of the car (including the fuel) is 6000 kilograms, and the mass of the fuel is one-third of the total mass of the car (i.e., 2000 killograms). The car is moved to the starting line (and left at rest), at which time the rocket is ignited. The rocket fuel is expelled at a constant speed of 900 meters per second relative to the car, and is burned at a constant rate until used up, which takes only 15 seconds. Ignore all effects of friction in this problem.Find the acceleration a_0 of the car just after the rocket is ignited
kinematic and dynamic
Because the fuel is used up in 15 seconds, the rate of the mass used = 2000/15 = 400/3 kgs-1.
That's all I can come up with...:cry:
Thanks
Hi songoku! :smile:
ok … so the change in momentum per second of the fuel is … ?
and so the change in momentum per second of the rocket is … ? :wink:
Hi tiny-tim :)
The change in momentum per second of the fuel = 400/3 * 900 = 120,000 N
The change in momentum per second of the rocket = The change in momentum per second of the fuel ??
Thanks
Hi songoku! :smile:
That's exactly right! :biggrin:
ok, now you want the acceleration …
and you have the rate of change of momentum, = d/dt (mv),
so acceleration = … ? :smile:
Hi tiny-tim :smile:
the rate of change of momentum = d/dt (mv)
120,000 = m *d/dt (v) ; m = 6000 kg
a = 20 ms-2
Now another question: find the velocity of the car when the fuel is about to be used up.
I think we consider when t = 15 seconds. And I've found that acceleration at t = 15 s is 30 ms-2 using the same method as you taught me.
But then I don't know how to continue...
Thanks
Hi songoku! :smile:
Why do you want the acceleration? :confused:
Just use conservation of momentum again. :wink:
Hi tiny-tim :smile:
Let : 1 = car ; 2 = rocket
I consider when t = 0 and t = 15
m1u1 + m2u2 = m1v1 + m2v2
0 (because u1 = 0) + 2000*900 = 4000*v1 + 0 (because m2 = 0 when t = 15)
v1 = 450 ms-1?
Thanks
Hi songoku! :wink:
Yes, that's right …
to put it in words: the momentum gained by the rocket-plus-remaining-fuel equals the momentum lost by the fuel, which is the mass of the fuel times the difference in velocity upon ejection, which at the end is the total mass of fuel times the (constant) relative ejection velocity, ie 2000 times 900. :smile:
Hi tiny-tim :wink:
Thanks a lot for your help !
hi, I have a same question : Find the final velocity of the car just as the rocket is about to use up its fuel supply.
I have tried exactly the same way, I used conservation of momentum, and got the answer Vfinal = 450 m/s.. but, the answer turned out to be wrong.. please advise.
Hm...how can you know that the answer is wrong? tiny-tim helped me and I also got the same answer (post #7).
that's why I don't know.. mastering physics said it wrong...
the question is Find the final velocity of the car just as the rocket is about to use up its fuel supply...
I just use the conservation of momentum and got the answer 450 m/s..but, it said the answer is wrong.
I still don't get it why the answer is wrong.. anyone please advise... :(
up up...
What is "mastering physics" ? I think the answer is 450 m/s. Maybe we should wait for other members to give their opinions here.
You should use the rocket equation:
"The differential equation for rocket motion is an example of a separable differential equation. It can be rewritten as
int(dv/dt)*dt = -v_ex * int(1/m)*dm
where the fact that a = dv/dt has been used on the left hand side. Thus, integrating the left side gives the change in velocity. Integrate the right side to get an expression for the change in velocity in terms of the initial and final masses."
This leads to: v_final-v_0 = v_ex*ln(m_0/m_final)
how can you get this equation?
and what is -v_ex?
Thanks
