Acceleration Question.Please Check My Answer
  • Thread starter Thread starter cbrowne
    Acceleration
The discussion focuses on calculating the acceleration and time taken by an electron accelerating in a cathode ray tube. The initial speed is 3.5 × 10^4 m/s, and the final speed is 1.4 × 10^6 m/s over a distance of 2.0 cm. The acceleration was calculated using the equation Vf² = Vi² + 2ad, resulting in approximately 4.9 × 10^13 m/s². For the time calculation, a mistake in the initial subtraction was identified, leading to a corrected time of approximately 2.8 × 10^-8 seconds. The final answers for both acceleration and time were verified as accurate.
cbrowne
An electron in a cathode ray tube of a TV set enters a region where it accelerates
uniformly from a speed of 3.5 × 104 m/s to a speed of 1.4 × 106 m/s in a distance
of 2.0 cm. (a) What is the acceleration of the electron in this region? (b) How
long is the electron in the region where it accelerates?
A) Vi= 3.5 x 104 m/s Vf= 1.4x 106 m/s
d= 0.02 m
Vf2= Vi2+ 2ad
(1.4x10^6)2 = (3.5x 10^4)2 + 2a(0.02)
(1.958775 x 10^12) = 2a(0.02)
(1.958775x10^12) = 0.04a
0.04 0.04
4.8969375x 1013= a
b) Vf= Vi+ at
(1.4x10^6)= (3.5x10^4)+ ( 4.8969375x10^13)t
136500 = 4.8969375x10^13t
4.8969375x10^13t 4.8969375x10^13t
= 0.000000003 --> t = 3.0x 10^-9
seems you used the correct equations, everything looks good to me!
cbrowne said:
b) Vf= Vi+ at
I believe you have a calculator error here; it looks like you dropped a zero on the left hand side. (1.4 million minus 35 thousand does not give a little over a hundred thousand.)
If you correct that, you should get the right answer for the time.
THANK SOO MUCH FOR NOTICING THAT MISTAKE! I end up getting 2.8 x10^-8 for my answer. Could you please verify this
That looks right to me.
