Calculating Acceleration of a Space Shuttle in Zero-Gravity Conditions
  • Thread starter Thread starter get_rekd
    Acceleration
In zero-gravity, the space shuttle's thrust is 2.4 X 10^7 N, while its weight on Earth is 2.0 X 10^7 N. To find acceleration, the mass of the shuttle must first be calculated using the formula W = mg, resulting in a mass of 2.0 X 10^6 kg. The net force acting on the shuttle is equal to the thrust, allowing the calculation of acceleration using F = ma. Ultimately, the calculated acceleration of the shuttle is 12 m/s^2.
get_rekd
When the space shuttle is flying in space, away from the influence of any gravitational fields, its engines provide a total thrust of 2.4 X 10^7 N. If the shuttle weighs 2.0 X 10^7 N on the surface of the earth, what is its acceleration? (use g=10 m/s^2)
Fg= (2.0 X 10^7 N)(10 m/s^2)
= 2.0 X 10^8 N m/s^2
Fnet= (2.0 X 10^8 N m/s^2)-(2.4 X 10^7 N)
= 1.76 X 10^8 N m/s^2
a= 1.76 X 10^8
I have absolutely no clue how to do this but this is what I have figured out can someone please explain for me?
If the shuttle WEIGHS 2 x 10^7 N on earth, then this is the force.
What you need to calculate is the mass of the shuttle using F = mg
The question states that it is away from the influence of any gravitational fields, so the net force is given by the thrust.
Using F = ma you can then determine the acceleration.
I'm sorry but I still don't understand.
so the mass of the shuttle would be 2 x 10^8 N then?
and Fnet= 2.4 X10^7?
hey, lol this looks awefully similar to a problem i have in my textbook.. but anyway
its like how he said, u have to remember that mass doesn't change, weight does. So in earth, you are given a weight. Therefore, you can find the mass of the shuttle. you see
W=mg (use 10 for your g), then once you have that..use F(thrust)= ma
simple heh
mass of the shuttle is in KG, and force is in NEWTONS (N), it is important to get the units right..
OK... If something weighs 2 x 10^7 N, then this is the force with which gravity is pulling it towards Earth.
Its mass can be determined from a rearrangement of F= mg (mass is measured in kg)
Now, if we have a mass shooting through space, being pushed by an engine with a force of 2.4 x 10^7 N, we can figure out its acceleration using a rearrangement of F = ma.
Note that these are two different cases, so the F in each is different.
right, use W=mg, because well its not wrong technically, but weight is a force, and in physics you generally use W for weight instead of Fg. anyway tell me what u get
and remember the mass doesn't change
I think my head is all goofed up today I just can't seem to do math correctly haa..
So I would then take,
2.4 X 10^7 N = (2.0 X 10^8 N)(a)
-2.0 X 10^8 N -2.0 X 10^8 N
-1.76 X 10^8 N = a??
lol, atleast you realized that is wrong.. but look acceleration is (m/s^2) force is (kg m/s^2) aka: mass x acceleration. anyway lol
2.0x10^7 N= mg (10=g)
then take that mass
2.4x10^7N=ma (a is what you solving for) if i do anything more, i will end up solving the problem
Not quite.
Your 2.0 x 10^8 is wrong.
W = mg
2.0 x 10^7 = m (10)
m=?
then use F(thrust) = ma
okay so then...
2.0 X 10^7 = m(10)
-10 -10
1.9 X 10^7 = m
2.4 X 10^7 N = 1.9 X 10^7(a)
-1.9X10^7N -1.9X10^7N
5.0 X 10^6 N = a
You are subtracting where you need to divide. - do the calculations again.
Other than that it looks ok.
Also, remember your units! acceleration is measured in m/s^2
LOL! sorry, not to be mean, but that was funny
alright so. For the 8th try haha! 2.4 X 10^7 N = 1.9 X 10^7 N a
then I divide 2.4 X 10^7 N by 1.9 X 10 ^7 N and get a
so a = 1.3 m/s^2
nope.. i don't know what to say lol,
okay so then...
2.0 X 10^7 = m(10)
-10 -10 (ERROR)-- fix that
1.9 X 10^7 = m (fix that)
2.4 X 10^7 N = 1.9 X 10^7 (fix that) (a)
-1.9X10^7N -1.9X10^7N (DIVIDE not multiply) 6=2x3 --> 3=6/2 or 2=6/3 (6-3 doesn't = 2-3)
5.0 X 10^6 N = a
Thanks a lot for the help guys. I appreciate it!
alright I think I figured it out now I hope to the lord.
2.0 X 10^7 N = m(10)
10 10
m= 2.0 X 10^6 N
2.4 X 10^7N = 2.0 X 10^6 N a
2.0X10^6N 2.0X10^6N
a= 12 m/s^2
good lol :)
finally! thank you so much for your patience and your help guys.
10 10
m= 2.0 X 10^6 N (should be Kg) just saying because if u are writing this problem down, i don't want you to get points off for that.
2.0X10^6N 2.0X10^6N
a= 12 m/s^2
okay thank you.
