Accelerations and rates at a far away point.
  • Thread starter Thread starter jean507
    Point
To calculate the accelerations and angular rates at the pilot's position from the center of gravity (cg) of an airplane, one must consider the distance characterized by a 3D vector (R) and the known accelerations and angular rates at the cg. The discussion highlights the necessity of having velocity data, as it is crucial for differentiating between rates and accelerations, especially in complex flight scenarios. The user is already integrating accelerations to derive speeds and displacements, which is a step in the right direction. However, the consensus is that additional information or methods may be required to accurately compute the desired values at the pilot's position. Understanding the relationship between acceleration and rotation is key to solving this problem effectively.
jean507
Considering I know the accelerations [ax, ay, az] and angular rates [p, q, r] at the center of gravity (cg) of an airplane. How can I calculate the accelerations and angular rates at the pilot's position (p).
I have information about the distance between the cg and the pilot's position which could be characterized by a 3 dimensional vector (R).
Any help would be appreciated.
Best regards to all.
You can't.
There isn't enough information.
Consider a simple situation where the COG measures a vertical acceleration. With no forward acceleration but a non-zero rotation in pitch.
This motion could indicate that the craft is climbing rapidly in a pure vertical accelerated ascent and rotating, or it could mean that it is spinning around an axis (looping).
You need the velocities. (Or you need to be able to derive them - which means integrating the acceleration over time)
I understand what you mean with your example, this is exactly what I could not understand (how to differentiate between a rate and an acceleration as they could have the same effect on a far away point).
I have a continuous signal over time. I am working with a flight simulation environment. As matter of fact, I am already integrating the accelerations twice to get the speeds and displacements.
Is it possible to do then? How?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
