According to Mary,how fast is the ball moving?
  • Thread starter Thread starter tanzl
    Ball
tanzl
Ted and Mary are playing a game of catch in frame S', which is moving at 0.600c with respect to frame S, while Jim, at rest in frame S, watches the action. Ted throws the ball to Mary at 0.800c (according to Ted) and their separation (measured in S') is 1.8*1012m.
I am confused by this question. Ted and Mary are moving at the same speed (0.6c relative to rest frame), so whatever observed by Ted should be consistent with Mary right? Since Ted observes that the ball is moving at 0.8c so Mary should observes that the ball is moving to her direction at -0.8c.
Yes, your correct; perhaps there is a typo in the question and you were meant to determine how fast Jim sees the ball moving?
Actually there are four parts in the question
(a) According to Mary, how fast is the ball moving?
(b) According to Mary, how long does it take the ball to reach her?
(c) According to Jim, how far apart are Ted and Mary, and how fast is the ball moving?
(d) According to Jim, how long does it take the ball to reach Mary?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
It's given a gas of particles all identical which has T fixed and spin S. Let's ##g(\epsilon)## the density of orbital states and ##g(\epsilon) = g_0## for ##\forall \epsilon \in [\epsilon_0, \epsilon_1]##, zero otherwise. How to compute the number of accessible quantum states of one particle? This is my attempt, and I suspect that is not good. Let S=0 and then bosons in a system. Simply, if we have the density of orbitals we have to integrate ##g(\epsilon)## and we have...
