What is the Acoustic Impedance of Wool?
  • Thread starter Thread starter Coolguynice
    Acoustic Impedance
The discussion centers on the challenge of determining the acoustic impedance of wool to calculate the reflective coefficient for sound energy. The reflective coefficient formula requires the sound impedance of both air and wool, but the user struggles to find specific values for wool. They mention a formula for calculating acoustic impedance based on density, pressure, and the speed of sound, but are unclear on the pressure variable and lack speed of sound data for wool. The conversation highlights the need for clarification on the type of wool being referenced and suggests searching online for acoustic impedance tables related to wool. Overall, the user seeks assistance in obtaining these critical values to complete their calculations.
Coolguynice
I need this to find the the reflective coefficient and multiply this by 100 to find the percentage of original energy reflected back however i cannot find the acoustic impedance of wool no matter how hard i try.
Im using the reflective coefficient formula which reads as ((Z2-Z1))^2/((Z2+Z1))^2 where z is a sound impedance. In this case Z1 is the sound impedance of air and Z2 is the sound impedance of wool. I also found a formula to calcualte acoustic impedance which reads as Z=density of material(pressure*speed of sound through the material) however it doesn't specify whether the pressure is a constant or not and like the acoustic impedance, i also cannot find the speed of sound through wool after all this time.
Any help or directions to decent sources would be extremely helpful. I know exactly what to do but these lack of values is holding me back from finishing anything else. Any help would be greatly appreciated.
When you say "wool" do you mean natural fiber sheep's wool, or something like mineral wool or glass wool or fiberglass wool which are commonly used as acoustic insulation?
Glass or fiberwool would be the best but honestly, at this rate i would be fine with any value regardless of the type of wool. Also thanks for replying.
You may have to do some prowling through the search results, but try Google with a keyword phrase like "Acoustic impedance table wool".
