MHB ACT Problem: Finding The x-Intercept Of Given Line
  • Thread starter Thread starter 816318
    Act Line
The x-intercept of the graph of the function y = x² – 4x + 4 is found by setting y to zero and solving the equation x² - 4x + 4 = 0. This can be accomplished using the quadratic formula or by factoring, resulting in the factored form (x - 2)² = 0. The solution indicates a repeated root at x = 2, meaning the graph touches the x-axis at this point without crossing it. Both methods confirm that the x-intercept is at the coordinate (2, 0). The discussion emphasizes the effectiveness of both the quadratic formula and factoring in determining the x-intercept.
816318
What is the x-intercept of the graph of y = x2 – 4x + 4?
How would you foil this?
Mathematics news on Phys.org
Re: ACT problem
To find the x intercept of the graph of the function $y = x^2 – 4x + 4$
We may either use the completing the square method or we may use the formula $x=\frac{-b}{2a}$
The easiest way is to use $x=\frac{-b}{2a}$
From $y = x^2 – 4x + 4$ which is in the form of $ax^2+bx+c$ we can find the values for $b$ and $a$ as $b=-4$ & $a=1$
$-b$ in the formula stands for the opposite of the value of $b$ in the above form.
$x=\frac{-(-4)}{2*1}$
$x=\frac{4}{2}$
$x=2$
using complete the square method to form the graph of the function of the form $y=\pm(x+b)^2+c$ or the vertex form
$y= (x^2 – 4x+(\frac{b}{2})^2 ) + 4 - (\frac{b}{2})^2 ) $
$ y=(x^2 – 4x+(\frac{-4}{2})^2 ) + 4 - (\frac{-4}{2})^2 ) $
$ y=(x^2 – 4x+4 ) + 4 - 4 $
$y=(x-2)^2$
which now the x means -b which is 2.
Now it can be seen using Desmos one $x$ intercept of both the forms is $(2,0)$
[graph]gf10si3evs[/graph]
Re: ACT problem
To find the $x$-intercept, we can set $y=0$ and solve for $x$:
$$x^2-4x+4=0$$
To factor, we need to look for two factors of 4 whose sum is -4, and we find:
$$(-2)(-2)=4$$
$$(-2)+(-2)=-4$$
Thus, the factored form is:
$$(x-2)(x-2)=0$$
or:
$$(x-2)^2=0$$
We have a repeated root, of multiplicity 2. Since the multiplicity is even, we know the graph will touch the $x$-axis without passing through it. Equating this factor to zero, we find:
$$x-2=0$$
$$x=2$$
Thus, we know the given graph has one $x$-intercept at $(2,0)$.
Re: ACT problem
$$x^2-4x+4=x^2-2x-2x+4=x(x-2)-2(x-2)=(x-2)(x-2)=0\implies x=2$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
