What is the Result of \(\vec{A} - \vec{B}\) Given Three Vectors Summing to Zero?
The discussion revolves around determining the result of the vector operation \(\vec{A} - \vec{B}\) given three vectors that sum to zero and are of equal length. Participants suggest that \(\vec{A} - \vec{B}\) can be expressed as \(\vec{A} + (-\vec{B})\). The equation \(C + A = -B\) is derived, leading to the conclusion that \(\vec{A} - \vec{B} = C + 2A\). The conversation emphasizes the importance of visualizing the vectors to understand their relationships better. Overall, the key takeaway is the mathematical relationship established between the vectors in the context of their sum being zero.
Ammar w
The diagram below shows 3 vectors which sum to zero, all of equal length. What is
\vec{A} - \vec{B}?
http://s3.amazonaws.com/diigo/thumb...Attempt at a Solution[/h2] I have no idea.
\vec{A} - \vec{B}?
http://s3.amazonaws.com/diigo/thumb... to get [itex]\vec A - \vec B[/itex] ? AM
Welcome to PF!
Hi Ammar w! Welcome to PF! :smile:
Draw -B …
what does it look like? :wink:
Thank you Andrew Mason & tiny-tim
C+A=-B // add A to the sides of the equatoin
C+2A=A-B
A-B = C+2A.
I didn't draw anything.
Thanks for let me thinking.
C+2A=A-B
A-B = C+2A.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
