Addition of velocities. relativity.
The discussion focuses on the addition of velocities in the context of relativity, specifically addressing three key points regarding the speed of light, denoted as c. It emphasizes that if a velocity V is less than c in one inertial frame, it remains less than c in all other frames. Additionally, if V equals c in one frame, it will equal c in any other frame. The conversation also touches on the challenge of proving that if V exceeds c in one frame, it will exceed c in all other frames, with participants seeking assistance for part a of the problem. The thread highlights the complexities of relativistic velocity addition and the implications for understanding the speed of light.
night
Show that the addition of velocities implies that:
a)if V < c in any inertial frame, then V < c in any other.
b)If V=c in one inertial frame, then V=c in the other.
c)If V>c in any inertial frame, then V>c in any other inertial frame.
Vx'=(Vx-c)/(1-vVx/c^2)
I did b) and I can't do a) and c)
Show us what you tried for part a.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
