Adiabatic Process: Burst Tire & Cloud Formation
An adiabatic process occurs when a gas expands or compresses rapidly without heat exchange with its surroundings. In the case of a burst tire, the rapid escape of air leads to cooling as the internal heat energy is used for expansion against external pressure. Similarly, in cloud formation, air expands and cools quickly, dropping below the dew point, causing water vapor to condense into clouds. Both examples illustrate that the speed of the process prevents heat transfer, resulting in cooler air. Ultimately, the key factor in these scenarios is the rapid expansion that leads to a temperature drop before heat can equalize.
Mareena
how is the rapid escape of air from a burst tyre and cloud formation in atmosphere an example of adiabatic process?
please explain
What do you understand by an adiabatic process?
A process in which no heat enters or leaves the system ?
I know in this process a gas expands or is made to get compressed very rapidly as the flow of heat requires finite time .. but am getting a bit confused with these 2 examples ?
on what basis have they been regarded adiabatic?
Yes its to do with speed of heat transfer and also the question of where will the heat go?
The second question is the significant one.
In both cases the air expands and cools as it expands because some of its internal heat energy goes to do the work of expansion against the external (air) pressure.
The expanding air becomes cooler than the surrounding air because heat does not have time to transfer. Eventually the temperatures will equalise.
In the case of the cloud formation the air cools sufficiently to drop below the local dew point and so some water vapour condenses out to form the cloud.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
