Advanced Higher Physics Investigation
The discussion revolves around finding alternative physics investigation topics for an Advanced Higher Physics course, as the initial idea of measuring the charge-to-mass ratio of an electron has been incorporated into the syllabus. Suggestions include exploring the Hall Effect and utilizing resources like Wikipedia for methods related to charge-to-mass measurements. Participants emphasize the importance of knowing the syllabus content to suggest relevant experiments. The need for three distinct experiments is highlighted, raising questions about whether they must be thematically related. Overall, the conversation seeks to identify feasible experimental topics within the constraints of the course.
Gizmo0105
As part of my Advanced Higher Physics course I am require to investigate an area of physics not covered by the syllabus. My first thought was to use telron tubes or similar in order to determine the charge to mass ratio of an electron. However it has just come to my attention that this has in fact been added to the course. Does anybody have any suggestions for similar areas of investigation?As far as I am aware I have to perform three different experiments and assosciated write ups.
Thanks in anticipation.
Gizmo
It would help to know what the syllabus/course does cover.
Well as far as I am aware the course covers the e/m determination using crossed fields. IF there were any other ways to find this then that would be great but I've yet to find any.
If you think you'd like to do charge-to-mass measurements, here's a place to start tracking methods down from: http://en.wikipedia.org/wiki/Charge-to-mass_ratio . Googling on
electron experiment "charge-to-mass ratio"
wll get you a ton of stuff, some of which has useful material on methods.
As for other areas of investigation, you could look at the Hall Effect. (I think I need to be more awake to come up with some other things you could try that could reasonably be done within a semester lab course.) Do all of your three experiments have to be on related themes? Is this largely an E&M lab course, or do you get into other branches of physics?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
9K
30K
