Advice needed regarding MgCl2 analysis and purification
  • Thread starter Thread starter treader
    Analysis
The discussion centers on the use of Dead Sea minerals, particularly MgCl2, for health benefits and personal use. The user expresses concerns about the purity of the minerals purchased, noting that the assay provided is incomplete and that previous lab-quality MgCl2 contained impurities unsuitable for human use. To ensure safety and quality, the user seeks advice on testing methods and potential labs, considering local university chemistry departments as a resource.Additionally, the user is interested in isolating MgCl2 from the other salts in the mixture for personal or commercial use. They inquire about the feasibility, complexity, and costs associated with this process, mentioning their current use of the minerals for bathing and the positive effects reported by friends. A response provides a method for isolating MgCl2 through a chemical process involving the conversion of MgCl2 to insoluble MgCO3 and subsequent reactions to regenerate MgCl2. The user appreciates the guidance and aims to pursue further inquiries in Thailand, noting challenges in obtaining expert advice locally.
treader
Hi,
I'm a newbie on this forum. My knowledge of chemistry is limited to High School, and what little I've picked up over the years.
I'm currently buying some minerals from the Dead Sea. There are supposed certain properties of these Dead Sea minerals that have made bathing in them popular for health reasons.
The main chemical I'm interested in is MgCl2. The assay on what I'm buying says merely, "46.89% MgCl2, 1.83% CaCl2, 0.59% NaCl, 0.31% KCl, with the rest (50.38%) being Water from crystallization".
This is a combination of salts that is intended for industrial use, but actually seems purer than the "Lab quality" MgCl2 that I bought previously, which was furnished with a more complete analysis from the manufacturer, and contained many impurities that would prohibit its usage for humans.
As the one from the Dead Sea is intended for industrial use, including feeding to livestock, it is probably not mandated that they provide a complete analysis. However, if I intend to use it personally, or even make a business out of it where I'm retired in Thailand - for conscience sake - I need to have it tested.
I would be grateful for advice on what kind of test to look for. I already contacted one lab that used some newer technology that, in fact, would not provide a complete chemical analysis. I was wondering if local University Chemistry departments might be a good place to look. There are many chemical testing facilities in Thailand, but the differ in capabilities.
The next step would be to try to isolate the MgCl2 from the rest of the minerals - making the end product of MgCl2 in crystalline and/or aqueous form. My question is: How difficult or expensive is this to do? How complicated is the process, what kind of equipment is necessary, and, would it be feasible to do starting out on a small scale.
At present, I'm buying 25 Kg sacks of the Dead Sea minerals for use as bath salts, or mixing it with water for external application. So far I've used it on myself, and find it relieves stress, pain, and improves the skin. Of the few friends I've given it to about 50% report positive results - sometimes in a matter of minutes. I've told them that "I believe" it's OK, but believing isn't good enough. I need assurance of its quality or a way to make it pure.
Any information you can provide would be of great help.
Thank you,
Treader
Chemistry news on Phys.org
OK, one way to isolate the MgCl2 is to convert it into the insoluble MgCO3 and treat with Cl2 or HCl to regenerate the MgCl2. The precise preparation is as follows:
1. Add your salts (MgCl2, CaCl2, NaCl, and KCl) to a solution of Selzter water (H2CO3) and ammonia.
2. Heat to just 50 C to cause the Mg(HCO3)2 to decompose into the insoluble MgCO3. Note, other bicarbonates formed are more stable.
Chemistry: Basically we are following the Solvay process (see Wikipedia Solvay Process at http://en.wikipedia.org/wiki/Solvay_process ), but using more dilute solutions and the unique low temperature thermal decomposition of aqueous Magnesium bicarbonate (see http://www.Newton.dep.anl.gov/askasci/chem99/chem99492.htm ).
Reaction for NaCl:
NaCl + CO2 + NH3 + H2O → NaHCO3 + NH4Cl (aq)
Similarly for MgCl2:
MgCl2 + 2 CO2 + 2 NH3 + 2 H2O → Mg(HCO3)2 + 2 NH4Cl (aq)
Then, upon mild heating:
Mg(HCO3)2 + H2O --Mild Heat--> MgCO3 (s) + CO2 + H2O
[Edit]: Do not directly treat aqueous MgCO3 with Chlorine as this could form HOCl (along with HCl). The products would then be MgCl2 and also some basic Magnesium hypochlorite. Better to convert the Chlorine water to HCl prior to reacting with MgCO3.
Alternately, one may be able to recover NH4Cl by concentrating and cooling the solute, precipitating remaining bicarbonates (all after extracting the MgCO3) and thereby forming aqueous NH4Cl. Then, heat the aqueous (or dry) NH4Cl with MgCO3 to form MgCl2:
2 NH4Cl + MgCO3 --> (NH4)2CO3 + MgCl2
On heating, the Ammonium carbonate breaks down into NH3 and CO2, thereby driving the reaction to the right.
Thanks AJ for your response. This gives me a solid basis to begin asking questions in Thailand. BTW - for a multitude of reasons, answers do not come easy in this place. I remember talking to many experts in many fields in the US who delighted in sharing their knowledge. Not so here.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
