Air chemical analysis "homemade"?
Air analysis around steelworks can be conducted to assess pollution levels, but reliable results typically require expensive equipment and expertise. For those seeking affordable options, purchasing a basic air quality meter online can provide some insights, particularly for specific pollutants like CO or NOx. It's also advisable to compare readings from different locations, such as urban centers, where pollution may be higher. In addition, contacting the steelworks for emission data or checking with local government agencies that monitor air quality can yield valuable information. However, concerns remain about the accuracy of sporadic measurements, as pollution levels may vary significantly over time and distance from the source, potentially leading to an incomplete understanding of local air quality.
Marvin94
I have a steelworks nearby my home. Is it possible to perform an air analysis in order to know how much the air is polluted? Which instrument do I need ? Are there cheap possibilities? Thanks a lot in advance for your help!
Chemistry news on Phys.org
Sorry, no way of making it cheaply, reliably, without expensive hardware and years of training.
Likes Marvin94
Thanks for your reply. Do you know however, how it should be performed?
What are you afraid of? If you are worried about something specific, like CO or NOX, go to ebay and by a cheap meter. Also do some measurements in the city center, it will probably be worse there.
You can also call the steelworks and ask if they can provide information on the emission levels. Probably there is also an external (government) agency that will measure emissions every once in a while. This might be information that must be made available to the public if they ask for it (in the US it is the freedom of information act I think).
I'm just worried about the steelwork near my home. Even if somebody measure emissions every once in a while, two problems can arise:
1) In some particular time frame (for example night) the steelwork could also emits more than usual pollution; it means that emissions control which are eventually done every once in a while could not really fully correspond to the reality.
2) The level of pollution, I think, is not the same in all the area. If I live near the steelwork maybe there is more pollution with respect to someone living far away. So a given measure is however not reflecting the effective pollution in every housing units.
However , thanks for your interest.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
