How to Design a High-Frequency Air Core Transformer for Low Power Applications?
To design a high-frequency air core transformer for low power applications using PCB conductors, specific details are crucial, such as the operating frequency, signal power requirements, and circuit impedances. Participants in the discussion emphasize the need for more information to provide effective assistance. Suggestions for resources like application notes or software tools are sought to aid in the design process. Providing comprehensive specifications will enhance the chances of receiving relevant advice. Clear communication of requirements is essential for successful collaboration in transformer design.
Eli Hait
Hi,
I need to design a high-frequency, low power air core transformer implemented by conductors printed on PCB.
Does anyone know about an application notes, free software or java applet which cam assist me in this case?
Thanx in advance
despair_eli
:cry:
:cry:
In order for anyone to help out . . . you need to provide a lot more information that you did.
What is the frequency involved?
How much signal/power you need to transmitt?
What are the impedances of your circuits?
Oleh
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
