Air pressure to energy, am I missing something?
The discussion revolves around the concept of using a balloon filled with pressurized air to generate energy through turbines. Participants explore the mechanics of energy transfer from the balloon to the turbines, the implications of air escaping the balloon, and the potential energy losses involved in the system.
  • Some participants suggest that energy losses occur due to heat generated from the balloon stretching and contracting, as well as friction from the air against the balloon.
  • Others propose that the compressor used to inflate the balloon must provide additional energy to spin the first turbine while also inflating the balloon.
  • A few participants question the setup, emphasizing that a balloon does not generate energy and that work must be done to fill it, which may lead to a misunderstanding of energy conservation in the system.
  • One participant clarifies that the system is intended to utilize energy from already pressurized gas rather than create net energy, highlighting the importance of understanding the mechanics of the balloon's expansion and contraction.
  • There is a discussion about the need for a clear mechanism explaining how the balloon expands and how energy is transferred to the turbines, with some participants emphasizing the importance of detailing the energy flow.
  • Some participants express that the setup does not violate physical laws, although it may be impractical for engineering reasons.
Participants express a mix of agreement and disagreement regarding the mechanics of energy transfer and the implications of using a balloon in this manner. There is no consensus on the overall efficiency or practicality of the proposed system.
Participants note that the discussion involves assumptions about the setup, such as the need for a resealable balloon and the conditions under which energy is extracted. The implications of pressure changes and energy losses remain unresolved.
Theravenhouse
Hello!
I've come across this forum looking for an answer to an odd question related to energy production. I have no intention of creating infinite energy so don't worry.
Imagine a very strong balloon with a cord wrapped tightly around it. The balloon expands pulling the cord which spins a turbine. All good so far. Now if I want to use the air escaping the balloon to spin a different turbine am I losing energy from the cord setup? As far as I can tell, both are using the psi to generate energy so it feels like they should cancel each other out but I don't see why they would. I assume this is a simple question with an obvious answer so I do apologize but it's been confusing me for several days
For 1) I'm pretty sure there are losses to heat in the balloon stretching and contracting.
There would also be frictional losses from the air against the balloon, and say you had 2 setups, both the same and pushed more air into 1 balloon, they would eventually come to equilibrium.
But what is the cord setup doing to the energy produced by the air escaping? Does it lose anything from the cord?
Theravenhouse said:
... Imagine a very strong balloon with a cord wrapped tightly around it. The balloon expands pulling the cord which spins a turbine. All good so far. Now if I want to use the air escaping the balloon to spin a different turbine am I losing energy from the cord setup?...
The way I see it:
The compressor that you use to inflate your balloon must provide extra energy to spin turbine #1 (work #1) via the wrapped cord, besides inflating the balloon (work #2).
Deflating the balloon transfers most of latent work #2 (elastic potential energy) into turbine #2.
The chord setup is either going to be stretching which generates heat or it's going to be sliding around the balloon which has friction, and therefore heat. Heat/friction = energy loss
Lnewqban said:
The way I see it:
Am I essentially just reducing the volume of the balloon and using up that extra psi at an earlier point in the process?
Whoa. Back up a second.
Why does the balloon expand? Is it rising?
What? Air is escaping the balloon? So it's not sealed?
OK, so it's not going to expand - it's going to contract.
I think you would do well to think through your setup carefully.
The biggest thig to examine that that a balloon does not generate energy. you might be able get some potential energy out of a system (say, a rising balloon pulling a string) but:
1] you had to put that energy in by doing work - eg. filling the balloon
2] it's not a cycle. It'll work once and then stop.
Why does the balloon expand? Is it rising?What? Air is escaping the balloon? So it's not sealed?
I'll clarify a lot:
This idea is for utilizing energy from already pressurized gas. It is not intended to create net energy but rather offset the energy used in pressurizing gas. Take propane for example, it has a volume 270 times that of it's container. So releasing it from a pressurized container into a balloon fills it up just fine.
That is when the balloon expands, it is not rising in my idea. It expands with compressed gas.
The balloon would have to be resealable (likely something more complex than a party balloon), so it could fill up then be expelled through a turbine then return to being sealed for future use.
What do you mean? Describe this in detail and we can start a discussion.
Waving your hands rapidly just moves the hot air.
Work done by pressure always involves a volume change
No. But of course once the air starts turning the first turbine you will only be getting energy at the second turbine.
By the way, the first turbine is confusing people because turbines are usually turned by gas and not strings. Your setup would be more understandable if it were described as follows:
A pressurized gas is injected into a piston and work is extracted from the piston as it expands. When it is expanded it is still under pressure. The pressure is released and used to drive a turbine.
Thank you! That is a much better way to explain it.
No problem! FYI, such a setup is perfectly fine. It does not violate any physical laws, although it probably would be discarded for engineering reasons.
"All good", as long as you say what it is that is making the balloon expand. You have to give a reason / mechanism for any change to a system, if you want to discuss what happens to the Energy.
You may have a 'reason' in your head but you need to be explicit.
You could, for instance, just be slackening the cord, allowing the balloon to expand (releasing some Potential (stored) Energy in the compressed air or you could be pumping air into the balloon / heating it up / changing the air pressure etc. etc.. The sign of the Energy flow is important.
Physics doesn't allow for Sky Hooks or Free Energy :smile:
A double expansion engine.
The Titanic had a triple expansion steam cycle, and/or four when the turbine was in use.
http://www.titanicology.com/Titanica/TitanicsPrimeMover.htm
A way to get as much out of the shoveling of tons of coal needed to power the vessel.
As do the steam turbines used in Power Stations, I believe, and aircraft turbo fans etc etc.
Theravenhouse said:
Hello!
Good! Welcome, thanks (that's why the forum is here for) and good that you're not ambitious for that infinite energy (etc.)
Indeed strange set-up (and I would be curious enough to see what your original motivation was etc. or how exactly your original idea came about etc. – although, I think you answered some of these [and more, etc.] in a subsequent post of your's that I liked ...), but the answer, AS YOU SAY, is INDEED really simple! :
These energies do not of course cancel each other out but they just add up, giving you the total energy. So you're not actually losing energy (in total), but yes you're losing it from one part (i.e. the cord set-up, in this case), coming out of the total energy ...
So it's actually like in the 'Conservation of Energy' arguments etc. ... , the reason basically of your not being able to create that infinite energy (or energy out of nothing) that you said yourself ...
[So bassically you had the question answered yourself ...]
Cheers
P.S. + energy possibly lost e.g. in friction and heat (etc.), as already mentioned by other member etc. ...
Comment from a pedantic old gimmer: If you think you've found some inconsistency in this 'Energy Thing' then you have to assume that you've forgotten something in the equation you have in your head.
Apart from in smart Alec mode, when e=mc2 gets brought into things, you can rely on Energy (i.e. all of it) is conserved. Also you can forget Relativity until your understanding of the classical stuff is pretty damn good. So just make a list of everything and eliminate a few that don't matter in your model and the change will be Zero. Sometimes it can be a simple matter of a sign you have used.
Theravenhouse said:
Hello!
If the external pressure doesn't reduce (from rising higher in the atmosphere for example) you need to pump air inside the balloon (consume energy) for it to expand and therefore produce energy by pulling the cord. By releasing the air inside the ballon, it will start deflating, no more producing air from the cord. You could then use the airflow to generate energy until the balloon empties out. The total energy produced by the cord and the airflow cannot exceed the energy required to inflate the balloon. Take also in account that the more you compress air (the air in the balloon will be under pressure), the higher its temperature rises, creating a temperature difference with the outside and higher rates of heat dissipitation (thermal energy loss).
Good first post @Daemius
Welcome to PF!
  • · Replies 32 ·
14K
