Algebra (probably easy) problem
  • Thread starter Thread starter Spirochete
    Algebra
The problem involves two equations, P/R = 3/5 and P/T = 9/10, and requires finding the value of (R+T)/R. The correct answer is 5/3, but the solver struggles to derive it. A key insight is that by solving for R and T in terms of P, the P variables can cancel out, allowing for a numerical solution despite having three variables. The discussion emphasizes that while typically a numerical value cannot be determined without knowing P, this specific case allows for cancellation leading to a solvable expression. Understanding how to manipulate the equations is crucial for arriving at the correct answer.
Spirochete
There are two equations and 3 variables and I'm asked to solve for the numerical value of a third expression:
We are told that
P/R=3/5
P/T=9/10
The question asks for the value of (R+T)/R
The correct answer is 5/3 but I have no idea how to get there. This is from a GRE practice test.
I tried addin' em together. Also solving for "P" to get rid of it doesn't work right away.
We are told that
P/R=3/5
P/T=9/10
Try solving the first equation for R and the second for T. Then substitute those values into the expression you need to evaluate.
oh I did not see in advance that the P's would cancel out like that and I'd get a number. I never would've thought to do that. Could you explain how you saw that?
When you have equations that share variables, you can always do that setup to eliminate the common variable.
Yes but you couldn't give a numerical value for just R+T, in this case you'd be left with 25P/9
This is to be expected. You can't get a numerical value for R unless you know P, and you can't get a numerical value for T unless you know P. Since you don't know P, you are not going to be able to get a numerical value for (R + T)/R.
You have 2 equations and 3 unknowns. Chances are, you will have a free variable.
Actually I believe this is a special case where you can get a numerical answer just because the P's happen to cancel.
